wjmnelis
[Solved] rpi0w freezes if Wifi comes back
Thu Feb 22, 2018 9:18 am
An RPi0W is used to control a home fan unit. Wifi is used to monitor the RPi0W and in a next phase, Wifi is needed to get the weather forecast. It is found that if the Wifi network is down for some time, the RPi0W often freezes at about the time the Wifi network becomes operational again.
The RPi0W is running the latest release of Raspbian Stretch Lite and there are currently no outstanding upgrades. Especially the wireless firmware release mentioned in viewtopic.php?t=203508 is included.
The last occurrence was on 2018.02.21. At about 07:02 the Wifi network became operational. However, the RPI0W could not be accessed through SSH, and it did not react on ping either. After a power cycle, the RPI0W becomes accessible. The various log files show entries up to the time that Wifi became operational. The messages in /var/log/syslog preceding the boot-messages are:
Feb 21 06:58:07 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Feb 21 06:58:13 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
Feb 21 06:58:27 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15
Feb 21 06:58:42 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
Feb 21 06:58:49 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
Feb 21 06:59:02 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Feb 21 06:59:08 rpi00 dhclient[424]: No DHCPOFFERS received.
Feb 21 06:59:08 rpi00 dhclient[424]: No working leases in persistent database - sleeping.
Feb 21 07:02:27 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
Feb 21 07:02:34 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
Feb 21 07:02:47 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
Feb 21 07:02:54 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
Feb 21 07:03:08 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 17
Feb 21 07:03:25 rpi00 dhclient[424]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
Feb 21 07:03:28 rpi00 dhclient[424]: No DHCPOFFERS received.
Feb 21 07:03:28 rpi00 dhclient[424]: No working leases in persistent database - sleeping.
A second RPi0W, used for tests and development, shows the same behaviour. It is running Raspbian Stretch with desktop. Once frozen, the TV screen does receive a signal via HDMI, but the screen is black. The keyboard is not operational, as it does not receive power any more via the USB connection. Also on this RPi0W, the last messages in syslog before the boot messages are dated 2018.02.21 07:03, and are also messages from dhclient.
I've played with enabling / disabling IPv6 (which is not used in my home network). Only once one RPi0W with IPv6 enabled was still operational after Wifi was restored, but it turned out to be just a coincidence.
The firmware versions are:
root@rpi00:/var/log# dmesg|grep -i firmware
[    0.270805] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:10
[   33.680910] brcmfmac: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[  627.766478] raspberrypi-firmware soc:firmware: Request 0x00040002 returned status 0x80000001
Power management on the RPi0W is turned off.
root@rpi00:/etc/network# cat interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
auto lo
iface lo inet loopback
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
wireless-power off
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
How to solve this issue?
lbog
Re: rpi0w freezes if Wifi comes back
Thu Feb 22, 2018 9:33 am
... and there are currently no outstanding upgrades. Especially the wireless firmware release mentioned in viewtopic.php?t=203508 is included.
Try with "scan_ssid=1" in the wpa_supplicant.conf file or/and with:
sudo apt-mark hold firmware-brcm80211
before update/upgrade.
wjmnelis
Thu Feb 22, 2018 10:21 am
Thanks for pointer. A test is now running using "scan_ssid=1" in the network section of /etc/wpa_supplicant/wpa_supplicant.conf. One RPi0W is rebooted afterwards, the other is not rebooted.
wjmnelis
Mon Feb 26, 2018 4:37 pm
Well, "scan_ssid=1" did not solve my issue. I'll try the other option.
RDPUser
Mon Feb 26, 2018 7:52 pm
Seems to be related with viewtopic.php?f=28&t=206510
Mon Feb 26, 2018 8:41 pm
We are actively investigating this, both at Pi towers and the wireless chip supplier. It appears to be a problem with the latest release firmware, so rolling it back should fix the problem (but bring some other ones back).
RDPUser
Mon Feb 26, 2018 10:47 pm
What is the easiest method to rollback the wifi driver after update?
RDPUser
Tue Feb 27, 2018 11:28 pm
Problem solved, copied the brcm folder of raspian Jessie to /lib/firmware/brcm
I've uploaded the files here, so you don't need to extract yourself https://workupload.com/file/2wjUFnk (easiest download) or http://www.share-online.biz/dl/QKNN0U4PE1
In case file is not available anymore: Files were extracted from http://director.downloads.raspberrypi.o ... jessie.zip
sudo mv /lib/firmware/brcm /lib/firmware/brcm-stretch
sudo mv [path_from_file]/brcm /lib/firmware/brcm
sudo apt-mark hold firmware-brcm80211 #prevent it from beeing updated
#back
#sudo apt-mark unhold firmware-brcm80211
wjmnelis
Wed Feb 28, 2018 10:04 am
On both RPi0W's a test is now running. Yesterday I've installed raspbian with kernel version 4.14.22, using `sudo rpi-update`. When the Wifi network became operational, this RPi0W restored it's wlan connection and did not freeze. The other RPi0W was frozen and needed a power-cycle to become accessible.
Today, a previous version of the firmware was installed on the second RPi0W, as described in the preceding post. (When I tried to get the firmware from share-online.biz, a pop-up appeared stating that I had won an IPhone. This website is now on my blacklist.) The RPi0W is rebooted. I'll report after the next Wifi outage.
Note that the 4.14.22 version includes the firmware released around 2018.02.07.
RDPUser
Wed Feb 28, 2018 10:58 am
Sorry, I've added another storage location. Sadly the file is too big for an attachment here in the forum https://workupload.com/file/2wjUFnk
Wed Feb 28, 2018 11:52 am
This should get the older firmware
wget http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-brcm80211_20161130-3+rpi2_all.deb
sudo dpkg -i firmware-brcm80211_20161130-3+rpi2_all.deb
And this will stop it being upgraded
echo "firmware-brcm80211 hold" | sudo dpkg --set-selections
wjmnelis
Fri Mar 02, 2018 1:51 pm
The installation of an older version of the driver fixes my issue. The RPi0W became accessible after an outage of the Wifi network. Further tests with kernel 4.14.22 showed that that version on an RPi0W does NOT always becomes accessible after an outage of Wifi.
For the time time, as long as I do not hit one of the issues 'unsolved' by installing an older driver.
wjmnelis
Fri Mar 02, 2018 1:53 pm
For the time being, as long as I do not hit one of the issues 'unsolved' by installing an older driver, my problem is solved.
Fri Mar 02, 2018 2:29 pm
I think the errors were more common if using the Pi as an access point, under certain circumstances. I was unable to replicate this "mailbox" issue that resulted, so it's not common. You should be OK.
RDPUser
Fri Mar 02, 2018 4:23 pm
I'm using PI as an accesspoint with hostapd and old driver version. It works so far without errors. However I don't use it excessively. It's only an access to the pi for a few command line options and streaming raspi camera video for some minutes.
nikeindahouse
Sun Mar 04, 2018 11:23 am
Does this apply only to the rpi0w? What about other pis? Are they affected too?
mcblack
Sun Mar 04, 2018 1:07 pm
I am encountering the same problem with two rasberrypi3 with newest rasbian stretch and internal Wifi, When I reboot my router the Pi looses wifi connection, when wifi is back on the Pi freezes and need to be restarted with a power cycle. My Pi's are configured with static ip, problem is the same when ip is assigned by dhcp.
Sun Mar 04, 2018 7:13 pm
All Pi's with wireless since they all use the same wireless chip and firmware.
mcblack
Sun Mar 04, 2018 8:14 pm
I solved My freezing problem with replacing attached drivers to /lib/firmware/brcm/
Drivers are copied from Jessie!
I also succesfully tried the drivers from Stretch Lite
brcmfmac_driver.zip
(241.23 KiB) Downloaded 110 times
kajan001
Re: [Solved] rpi0w freezes if Wifi comes back
Tue May 21, 2019 7:08 pm
It's now 2019. Has the issue with the firmware been fixed?
I am experiencing a similar issue with to Rpi0w. The both randomly freeze and I suspect an wifi issue.
I have ruled out psu and cable issues, as well as bad sd cards.
Having connection 49/50 and -61 dbm, not great but is it bad enough to freeze the system?
RDPUser
Thu Jul 11, 2019 10:54 pm
The issue is long fixed with official binaries. I use a few PIs (3 and Zero W) in Wifi and none freezes.
A Pi Zero W is working for month stable. Data is requested over Wifi every minute. It also fetches data every minute.
How do you know the system freezes? Did you connect via serial console to see if PI is still up? I suspect some kind of incompability with PI and your Wifi hardware. Some APs make quite a lot trouble, not only with PIs.
To test if that particular issue is affecting you: Connect PI to Wifi, then reboot AccessPoint. If PI never connects again it is likely this issue. But as I said, this issue is long gone for me.
bryan.crotaz
Sun Oct 20, 2019 3:48 pm
I'm seeing this same problem on 4 new ZeroWs. I've tried with latest Stretch Lite and latest Buster Lite (sep 2019).
On two of the ZeroWs I've installed the UFL socket to improve wifi signal - this makes no difference to the failure, although signal quality is much improved.
Symptoms:
On boot, about 20% of the time it does not connect to wifi.
On a successful boot the OS hangs after 20 mins - 3 hours.
After boot the system is idle with just another machine pinging it every second to track whether it is active on wifi
Wifi power management is disabled in rc.local
OS hang means:
- does not respond to USB keyboard
- disconnects from wifi and cannot be pinged
- HDMI is active showing no error messages
- nothing interesting in syslog or kernel log following a power cycle
