DavidPoolCar
RPI touchscreen dead column
Mon Feb 19, 2018 5:41 am
Hi there,
First time poster, be gentle. I've being working with some raspberry pi's at work, and I've discovered a problem with some of the raspberry pi touchscreens. Thought I might check if anyone else has encountered the problem and has a fix.
It appears that the touchscreen has a dead touch column (in Portrait mode, I guess it would be row if held landscape) straight in the middle of the screen, which is a problem because there's buttons in the center that I need to press. It appears to work intermittently however, as after a series of touches at varying pressure it eventually works.
If pertinent the application I'm running is a web page in Flask, but it appears to be affected across more than just that app.
Any ideas?
texy
Re: RPI touchscreen dead column
Mon Feb 19, 2018 9:44 am
Hi and welcome to the forum.
Which touchscreen - the official Raspberry Pi 7" touchscreen?
Texy
DavidPoolCar
Mon Feb 19, 2018 9:42 pm
Hi there,
Sorry should have confirmed that in my first post, yeah it's the official Raspberry Pi touchscreen.
pvdmeer
Mon Nov 12, 2018 8:20 am
Have the same problem. About 10% of the official touchscreens we used have degraded or totally dead touch area. Have you come up with a fix for this?
Scott114
Tue Jan 29, 2019 8:52 am
I'm also facing the issue, please help me to resolve this issue. vidmate
JBeebout
Tue Jul 21, 2020 6:11 pm
I am planning to deploy a few hundred of these touchscreens, this 10% failure rate is concerning, but there are not many similar products available. (most OEM screens use HDMI) what quantities were you using to experience this failure rate?
