SamPhoenix
dhcpcd static IP error...
Wed Feb 14, 2018 9:20 pm
I have been using my pi as a homeassistant hub and assigned it a static ip address... It had been working fine for a while and a few days ago it stopped connecting to the network. Upon restarting it, I saw that the it said that dhcpcd.service failed to start so I look into it and find:
Not running dhcpcd becsuse /etc/network/interfaces defines some interfaces that will use a DHCP client or static address
I have no idea how to fix this... Any help would be appreciated.
SurferTim
Re: dhcpcd static IP error...
Wed Feb 14, 2018 10:14 pm
Post the contents of your /etc/network/interfaces file.
SamPhoenix
Wed Feb 14, 2018 10:53 pm
auto lo
iface lo inet loopback
iface eth0 inet static
 address 192.168.0.4
 netmask 255.255.255.0
 gateway 192.168.0.1
 dns-nameservers 8.8.8.8 8.8.4.4
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant.conf
iface default inet dhcp
SurferTim
Wed Feb 14, 2018 10:58 pm
If you are using the Stretch version of Raspbian, remove all that. There should be only one uncommented line in /etc/network/interfaces unless you are setting up a bridge, which you aren't.
SamPhoenix
Wed Feb 14, 2018 11:09 pm
I am, so what should I do to keep the static IP but have it actually working?
SurferTim
Thu Feb 15, 2018 1:21 am
If you are using Stretch, open /etc/dhcpcd.conf with a text editor. There are plenty of commented out examples there.
SamPhoenix
Thu Feb 15, 2018 1:49 am
But I'm confused about what you told me to remove and keep and what needs to be added.
Thu Feb 15, 2018 7:43 am
The current version of /etc/network/interfaces contains the following lines only:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
If you want to set a static IP on an interface, do what it says and
or ask here with details of what you want to set and we'll tell you what you need to put in /etc/dhcpcd.conf
pcmanbob
Thu Feb 15, 2018 12:21 pm
Or there are always the excellent learning resources that are available on the pi web site
https://www.raspberrypi.org/learning/ne ... p-address/
lizaborne00
Sat Mar 30, 2019 2:59 pm
as per my opinion you reinstall and update your system
