sudopiroot
raspberry pi zero w headless set up - SOLVED
Mon Jan 22, 2018 8:00 pm
I'm having trouble getting my first raspberry pi zero w set up!
I cannot see the pi on my network.
ssh and wpa_supplicant.conf have both been dropped into /boot
contents of wpa_supplicant.conf
country=US
update_config=1
network={
 ssid="Range2.5x"
 psk="password"
 key_mgmt=WPA-PSK
any suggestions?
klricks
Re: raspberry pi zero w headless set up
Tue Jan 23, 2018 5:06 am
.....ssh and wpa_supplicant.conf have both been dropped into /boot...
The files go into the root level of the SD card. NOT in /boot
When successful the files will be automatically deleted on RPi boot.
So if you put the SD card back into the PC and the 2 files have disappeared, then you know that ssh is enabled and the WPA file was moved to the proper location. (Doesn't however necessarily mean that the content of the WPA file is correct).
Note the the root level of the SD card becomes /boot when booted in the RPi but when read in a Windows or MAC it is at the root level.
Also you must be using the standalone version of Raspbian..... NOT NOOBs.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
sudopiroot
Tue Jan 23, 2018 5:38 am
I'm using a Mac so I really meant to say /Volumes/boot (which is in fact the root directory, sorry about that).
yes, I have the latest stretch image
however, I'm really dumb and accidentally did not capitalize the "x" in my network name :oops: :evil: :lol:
thank you so much for reaching out, but I'm afraid we would've never gotten this one solved if I hadn't realized how stupid I am :lol:
