FormellaJ
HDMI Installation Caused Kernel Panic
Fri Jan 19, 2018 7:26 pm
After installing the drivers and software for a 5" HDMI display and updating the pi, we got an "end kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block (179,2)" error on boot up.
We have tried to change the code to "...(179,6)" but this did not work as well.
Is there a way to boot the pi back up to the desktop while keeping the software so that the display still works?
Thanks.
Re: HDMI Installation Caused Kernel Panic
Fri Jan 19, 2018 11:46 pm
That means your filesystem is screwed and needs a fsck run on it. Nothing to do with HDMI, it's more likely caused by pulling the power.
Get another SDCard and USB reader. Download Raspbian Stretch and Etcher. Use Etcher to write Raspbian to the new SDCard. Boot that. Mount the bad SDCard in the USB reader. Open an LXTerminal window and run the following
sudo umount /dev/sda2
sudo fsck -f -y /dev/sda2
sudo poweroff
Swap the cards, and boot normally.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
klricks
Sat Jan 20, 2018 1:28 am
What drivers and software? A HDMI screen should just work with no added drivers or software.
Go here for my RPi writeup. Basic config, Serial Port add-on etc:
http://blackeagle12.net/Comp/RPi/Rpi.html Click contact icon then world icon --->
Who is online
Users browsing this forum: gyrotech and 53 guests
