Zombigamer02
My Raspberry Pi is using a LAN IP Address
Fri Jan 19, 2018 2:30 pm
AS A STARTING NOTE; I HAVE NO IDEA WHAT I AM TALKING ABOUT I AM NEW
Basically what I believe the issue is, is that my Raspberry Pi [RP] won't generate a normal 192.xxx.xxx.xxx ip address.
Instead, it generates a 10.0.0.85 ip. I have spent many hours trying methods, from "ifconfig" to "localhost -I".
I need the ip so that I can remote desktop connect from my windows PC via xrdp. I got it working using the 10.0.0.85 ip and then rebooted the RP. It wont work anymore. My remote desktop cant connect at all to the xrdp service. I am desperate for help and am on my last legs :cry: . Willing to try any damn method!
Cheers!
mattmiller
Re: My Raspberry Pi is using a LAN IP Address
Fri Jan 19, 2018 4:32 pm
Hi and welcome to the forum
1. Tell us what model Pi you have got, how are you connecting to your router (LAN cable or WiFi)
2. Start gain with a clean full Raspbian image
3. Don't try and use xrdp - Pi uses VNC as main remote desktop software -xrdp can be used but wait until you've got some experience with your Pi before going down that route
ericcooper
Fri Jan 19, 2018 5:40 pm
Both 192.168.0.0/16 and 10.0.0.0/24 are reserved IP address ranges commonly used in LANs. So the router in your network is probably handing out an address in that range to your Pi, in response to its DHCP request.
pcmanbob
Fri Jan 19, 2018 8:21 pm
presuming you windows pc is working correctly you can find out what address range is being used by your routers DHCP like this.
ON WINDOWS PC
press windows key + r( or find Run via the start button )
type cmd in the field and hit enter
in the new window type ipconfig
it will return the networking address details for the windows pc
I suspect it will be a 10.0.x.x address, the same address range you pi was getting.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Zombigamer02
Fri Jan 19, 2018 11:05 pm
1 Raspberry Pi 3 B
2 I have done so twice
3Am I able to still connect using windows remote desktop connection using VNC?
Zombigamer02
Fri Jan 19, 2018 11:07 pm
My PC has a normal IP?
I there a way to get a normal IP?
Zombigamer02
Fri Jan 19, 2018 11:09 pm
ON WINDOWS PC
My PC has a normal IP? Is my router forcing a 10.0.0.X on my RP? Is there a way to change this?
pcmanbob
Fri Jan 19, 2018 11:20 pm
What IP did you windows pc have then ? When you ran the instructions I posted.
Your router can't assign addresses from the 192.168.x.x range and the 10.0.x.x range at the same time it will only have one LAN address range.
What router are you using and what else is connected to it.
FTrevorGowen
How are your PC & Pi connected to the router? (ie. both wired, both WiFi or a mixture of wired & WiFi).
What's your router make/model? Can you log in to it to see how it's configured?
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
mattmiller
Fri Jan 19, 2018 11:22 pm
Just try and follow pcmanbob's instructions - then we will know more information about your setup
Zombigamer02
Fri Jan 19, 2018 11:31 pm
IPv4 Address. . . . . . . . . . . : 192.168.56.X
ISP provided router. TELSTRA, TECHNICOLOUR TG784
Zombigamer02
Fri Jan 19, 2018 11:34 pm
Trev.
Both ethernet, my pc does not have wifi capabilities.
TELSTRA TECHNICOLOUR TG784
I am able to access my router via chrome.
neilgl
Sat Jan 20, 2018 12:30 am
Can you log on to the admin page of your router and let us know what devices are connected on what ip?
klricks
Sat Jan 20, 2018 2:17 am
...Am I able to still connect using windows remote desktop connection using VNC?
Download the appropriate client viewer from here: https://www.realvnc.com/en/connect/download/viewer/
RealVNC is much much better than rdp.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
pcmanbob
Sat Jan 20, 2018 9:39 am
If you windows pc has a 192.168.56.x IP then your router should have given the same IP to your pi with just a different last number.
if you got a 10.0.0.x IP on the pi there must be another DHCP running on your network which issued the IP so what else have you got connected to your router ?
Try connecting just your windows pc and your pi to the router and see what IP you get on both devices then.
mattmiller
Sat Jan 20, 2018 10:11 am
Can I suggest that only pcmanbob helps the OP at the moment as I think we are bombarding them with too many questions/suggestions?
bensimmo
Sat Jan 20, 2018 10:40 am
That's the old Thomson router (now Technicolour)
It's a basic router, you don't need to set anything on the Pi other than enable VNC on raspi-config and use VNC viewer, see here https://www.raspberrypi.org/documentati ... /README.md
Honestly, start fresh again as any alteration trying to make it work may be making it worse.
Do nothing other than connect to the network.
Ethernet, just stick it in
WiFi just do what you normally do.
(WHICH are you using?)
I can only think this is if this is WiFi you may be connecting to a Guest account the routers sometimes have (the newer Technicolour do) and somehow you managed to work across the IP range.
Anyway, download FING it gives a nice way to scan what your computer can see on the network https://www.fing.io/download-free-ip-sc ... ndows-osx/
If you have a mobile phone garb the app and it even easier.
You IP address will not stay the same all the time, you can tell the router to keep its IP address. You don't alter anything on the Pi.
Once you have a clean Pi install, have it connected to the network and vnc enabled.
Answer pcbobs questions.
Mention if it is WiFi or Ethernet front he Pi.
If you have a WiFi extender and are connecting to that?
Etc
Take pictures if you like :-).
