RlTA
Zero W WiFi unable to use wpa_supplicant
Fri Jan 19, 2018 4:05 am
I recently bought a zero w and flashed an sd card with the latest raspbian.
I was able to boot up the system with no problems at all, but as soon as I tried to get this connected to a Wi-Fi network, the wpa_supplicant would not work properly and scan any APs.
I tried different versions of raspbian and I even used volumio, but these did not solve the issue.
I attached a file that I used for the wpa_supplicant.conf and the prompt output of the command below.
sudo wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant.conf -i wlan0 -Dnl80211,wext -dd
One thing I noticed from the prompt output is that the wpa_supplicant actually makes a WPA Handshake with the AP successfully, and then gets a deauth from local reason for somehow.
I do not know if this is a hardware problem or a software problem, but from hours of googling, I am starting to think that the one I received from Argon40 is a defective one.
Any help would be appreciated.
+ the /proc/cpuinfo tells me the correct Serial and cpu/board information
Documents.zip
(7.36 KiB) Downloaded 8 times
Using: RPi Zero W
Odroid C2
neilgl
Re: Zero W WiFi unable to use wpa_supplicant
Sat Jan 20, 2018 12:19 am
Ah, I copy a wpa_supplicant file to the "boot" partition of the SD card from my pc after using win32diskimager (or etcher) for pi zero W
Then it works on wifi. This is what is in that file:
update_config=1
country=UK
network={
	ssid="YourSSID"
	psk="YourPASSPHRASE"
	key_mgmt=WPA-PSK
