Tony Harris
Pi Zero W No WiFi Possible Board Revision Issue [solved]
Tue Jan 16, 2018 11:42 pm
Hello
First post.
Trying to diagnose my Pi Zero W's 'No WiFi' problem has led me to believe that I have an incorrectly programmed board.
/proc/cpuinfo contains revision value 000f whereas Line 30 in vcgencmd otp_dump contains value of 00000000
I've tried various Stretch and Jessie packages and everything else on the Zero W seems to work ok, including wlan0 if I add a usb wifi dongle but the symptoms are no onboard wifi and no act led. All packages work fine on my Pi3
I'd be grateful for any help as to whether I'm on the right track with my diagnosis.
Thanks in advance, I can provide more details if needed.
mattmiller
Re: Pi Zero W No WiFi Possible Board Revision Issue
Wed Jan 17, 2018 8:37 am
For the sake of another $10 (plus taxes and shipping) - I'd get another PiZeroW as its going to be by far the easiest way to determine whether you have a hardware or a software issue
Tony Harris
Wed Jan 17, 2018 8:47 am
I've got one of the new ones with pre-soldered header on order. Still keen to understand the technical issue.
mattmiller
Wed Jan 17, 2018 9:01 am
IMO - the quickest way to understand the technical issue is to have another one to compare/contrast :)
RaTTuS
Wed Jan 17, 2018 9:11 am
means it thinks it is a pi1 there is a way of reprogramming it but I dont know how OTTOMH
Covfefe
piglet
Wed Jan 17, 2018 9:27 am
I didn't know what OTTOMH meant, off the top of my head.
RaTTuS
Wed Jan 17, 2018 9:28 am
;-p ... currently trying to find a post on how you program the bits if they have not been set ....
Covfefe
RaTTuS
Wed Jan 17, 2018 9:41 am
see
viewtopic.php?f=43&t=160611
someone will be ablong at some stage to tell you how to to make it permanent
Covfefe
Tony Harris
Wed Jan 17, 2018 11:51 am
Thanks for that link, I tried to force it using the info here https://github.com/raspberrypi/firmware/issues/758.
But that resulted in no boot and continuous 4 long 4 short act led flashing, first time I'd seen the act led light up though!
I'll try the other values and report back.
Tony Harris
Thu Jan 18, 2018 8:39 am
Forcing it with 0x900093 brings the act led to life and it boots ok, but still no wifi.
There's more info here viewtopic.php?t=178362
Looks like there may be a few of these about.
Tony Harris
Fri Jan 19, 2018 7:08 pm
Update, have received new Zero W and its cpuinfo version and line 30 of vcgencmd otp_dump both read 009000c1
So my initial diagnosis appears correct.
Hope this helps anyone else with the same symptoms.
jesperdj
Re: Pi Zero W No WiFi Possible Board Revision Issue [solved]
Sat May 12, 2018 10:18 pm
That's because code 0x900093 is for the Pi Zero V1.3 which does not have WiFi / bluetooth and not the Pi Zero W.
You would need to use 0x9000c1 instead for the Pi Zero W V1.1 as you can see in this table: https://elinux.org/RPi_HardwareHistory
