hippy
[SOLVED] python-scrollphathd upgrade problem
Sun Jan 14, 2018 9:01 pm
Just doing my weekly sudo apt-get update/upgrade on my Pi 3B and got this ...
Unpacking python-scrollphathd (1.1.0) over (1.0.1) ...
Preparing to unpack .../5-python3-scrollphathd_1.1.0_all.deb ...
Unpacking python3-scrollphathd (1.1.0) over (1.0.1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-penvD7/5-python3-scrollphathd_1.1.0_all.deb (--unpack):
 trying to overwrite '/usr/bin/scrollphathd_api', which is also in package python-scrollphathd 1.1.0
[email protected]:~$
I unsurprisingly now get this error every time I upgrade. Not quite sure what the error or issue is. I'm logged in as the Pi user, am using sudo apt-get upgrade, the file it seems to be trying to overwrite exists ...
[email protected]:~$ ls -l /usr/bin/scrollphathd_api
-rwxr-xr-x 1 root root 414 Jan 11 11:25 /usr/bin/scrollphathd_api
Tried renaming ''/usr/bin/scrollphathd_api" to something else, but still get the same error.
Any idea how I fix whatever the issue is or make the error when I upgrade go away ?
cjan
Re: python-scrollphathd upgrade problem
Sun Jan 14, 2018 10:03 pm
same here +1.
DavidMS
Sun Jan 14, 2018 10:19 pm
same for me, interestingly if you do an apt-get install it will finish off the aborted update when it has installed the new application which I guess makes sense
http://meanderingpi.wordpress.com/
11 Raspberry Pi's and counting....
Sun Jan 14, 2018 10:51 pm
cd /var/cache/apt/archives
sudo dpkg -i --force-overwrite python3-scrollphathd_1.1.0_all.deb
It's a bit crude but resolves the problem. No idea why we need that package in a standard Raspbian install since it's for special hardware.
I'll do your homework for you for a suitable fee.
davidcoton
Sun Jan 14, 2018 11:37 pm
DougieLawson wrote: No idea why we need that package in a standard Raspbian install since it's for special hardware.
Two possible reasons:
  1. Mistake :o :shock: :?
  2. Preparation for h/w built in to imminent Pi4B :twisted:
Signature retired
hippy
Mon Jan 15, 2018 12:03 am
I couldn't figure out how you exactly meant by "apt-get install". Without any package name ? I tried "sudo apt-get install python3-scrollphathd" but got the same error. But this worked -
sudo apt-get remove python3-scrollphathd
So I then did -
sudo apt-get remove python-scrollphathd
Everything seems to be working now and I've got a little more disk space.
It is coming up to the launch anniversary date so we can let the speculation run free. My guess would be -
Free Scroll pHAT HD with the March MagPi.
Pimoroni are preparing a Zero WH plus Scroll pHAT HD bundle.
John Mc
Mon Jan 15, 2018 5:17 am
I believe that should be cd /var/cache/apt/archives
(note the "s" on the end of archives)
DavidMS
Re: [SOLVED] python-scrollphathd upgrade problem
Mon Jan 15, 2018 12:54 pm
I just did a sudo apt-get install pip - it reported the current version was latest and then carried on with the 35 files it miss the first time
Luigi3711
Mon Jan 15, 2018 9:31 pm
I have the same problem, but nothing is working. In almost every line, it has something to do with a java plugin and armhf.
Mon Jan 15, 2018 9:36 pm
sudo dpkg -i --force-overwrite /var/cache/apt/archives/python3-scrollphathd_1.1.0_all.deb
Luigi3711
Mon Jan 15, 2018 10:36 pm
When I enter the command, I get this:
[email protected]:/var/cache/apt/archives $ sudo dpkg -i --force-install /var/cache/apt/archives/python3-scrollphathd_1.1.0_all.deb
dpkg: error: unknown force/refuse option 'install'
Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
It seems that there is more than one problem.
I also found lines that said something about a java plugin and armhf.
Mon Jan 15, 2018 11:08 pm
Sorry it's --force-overwrite (should have checked my other posts).
Luigi3711
Mon Jan 15, 2018 11:43 pm
Nothing seems to be working.
hippy
Tue Jan 16, 2018 6:42 pm
Just to round off the thread. It appears to have been a mistake / oversight -
viewtopic.php?f=116&t=202583#p1259740
And, from that, it seems the issue has been resolved and is working its way out for future updates.
