situation23
SD card corrupt
Wed Jan 03, 2018 5:01 pm
I loaded a raspberry image and everything worked perfectly. Then the next day I come back and it is off? But I restart it and nothing happens so I decided to format the sd card with a new os and windows will not let me do anything. I have tried cmd and regedit. and NOTHING..... I dont care about the data on the card I was just testing out some new gear. I just want to be able to use this sd card again. Can anyone help me? Thanks!
Re: SD card corrupt
Wed Jan 03, 2018 5:26 pm
Just reimage the card with etcher, as you presumably did originally. You don't need to reformat, etcher will overwrite everything on the card.
Please direct all questions to the forum, I do not do support via PM.
situation23
Re: SD card corrupt
Wed Jan 03, 2018 5:38 pm
I tried that it says not enough space? its a 32 gb card
drgeoff
Re: SD card corrupt
Wed Jan 03, 2018 6:29 pm
Please confirm that you are trying to use Etcher to write an image to a 32 Gbyte card and Etcher says not enough space.
situation23
Re: SD card corrupt
Wed Jan 03, 2018 6:30 pm
yes i am
Re: SD card corrupt
Wed Jan 03, 2018 6:39 pm
yes i am
In that case see if SD Card Formatter recognises as a 32GB Card:
https://www.sdcard.org/downloads/formatter_4/
If not recognised then boot your x86 machine with a Linux LiveDVD and use gparted ;)
Adieu
situation23
Re: SD card corrupt
Thu Jan 04, 2018 2:24 am
yes i am
I used the gparted and could not get it to work. Unless i am using incorrectly. ......
Re: SD card corrupt
Thu Jan 04, 2018 10:42 am
https://gparted.org/display-doc.php?name=help-manual
Adieu
situation23
Re: SD card corrupt
Thu Jan 04, 2018 2:34 pm
I used that and some youtube videos to guide me. The same problem still exists such as it only shows the 30 mb when it should be 32 gb. Even creating a new partition doesn't work because there is not enough space.
Re: SD card corrupt
Thu Jan 04, 2018 2:41 pm
Fake SD Card ??
https://sosfakeflash.wordpress.com/h2testw/
Adieu
situation23
Re: SD card corrupt
Thu Jan 04, 2018 5:25 pm
Fake SD Card ??
no it worked before and i got it at walmart with two other ones that work fine?
mattmiller
Re: SD card corrupt
Thu Jan 04, 2018 5:40 pm
Do you have a digital camera that takes SD cards and try it out in one of them to see if it basically still working and not broken?
drgeoff
Re: SD card corrupt
Sun Jan 07, 2018 9:56 am
Use gparted to delete ALL the existing partitions. Then use it to make a single partition that uses the whole 32 Gbyte.
Who is online
Users browsing this forum: droleary, The Traveler and 75 guests
