So, I got Raspbian installed and up and running. For some reason, after installing the VNC add on in the menus the system started giving me the bad filesystem error.
I thought, "Hey, I can just reformat and start again."
No such luck. I am now stuck with a micro SD card (32GB) that has a 40 MB partition in FAT32, a 4 MB unallocated space, and the rest is ext4.
I have tried windows command prompt, gparted, disk manager, dd command in terminal, fdisk and many others. Every time I format it and save the changes, every program will appear to be doing something and then it refreshes and nothing has changed. The partitions will not resize, move delete, format, or anything.
I need help to recover my SD card. I can't even use the free space on it or delete any files on it manually.
Has Raspbian killed my SD card?
