Problem during sudo apt-get dist-upgrade (Pi B+)
Posted: Tue Dec 26, 2017 12:32 am
by KevF
I'm a total Linux beginner trying to update my python & GPIO packages
I tried an upgrade via the sudo apt-get dist-upgrade command but ran into problems .......
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
libpython2.7 : Depends: python2.7 (= 2.7.3-6+deb7u4) but 2.7.3-6+deb7u2 is installed
libpython3.2 : Depends: python3.2 (= 3.2.3-7+deb7u1) but 3.2.3-7 is installed
python2.7 : Depends: python2.7-minimal (= 2.7.3-6+deb7u2) but 2.7.3-6+deb7u4 is installed
python2.7-dev : Depends: python2.7 (= 2.7.3-6+deb7u4) but 2.7.3-6+deb7u2 is installed
Depends: libexpat1-dev but it is not installed
python3.2 : Depends: python3.2-minimal (= 3.2.3-7) but 3.2.3-7+deb7u1 is installed
python3.2-dev : Depends: python3.2 (= 3.2.3-7+deb7u1) but 3.2.3-7 is installed
E: Unmet dependencies. Try using -f.
I tried $ sudo apt-get -f install but then get unpacking problems .......
Correcting dependencies... Done
The following extra packages will be installed:
libexpat1-dev python2.7 python3.2
Suggested packages:
python2.7-doc python3.2-doc
The following NEW packages will be installed:
libexpat1-dev
The following packages will be upgraded:
python2.7 python3.2
2 upgraded, 1 newly installed, 0 to remove and 197 not upgraded.
12 not fully installed or removed.
Need to get 5,386 kB of archives.
After this operation, 176 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python2.7 armhf 2.7.3-6+deb7u4 [2,671 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python3.2 armhf 3.2.3-7+deb7u1 [2,504 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libexpat1-dev armhf 2.1.0-1+deb7u5 [211 kB]
Fetched 5,386 kB in 4s (1,105 kB/s)
(Reading database ... 77277 files and directories currently installed.)
Preparing to replace python2.7 2.7.3-6+deb7u2 (using .../python2.7_2.7.3-6+deb7u4_armhf.deb) ...
Unpacking replacement python2.7 ...
dpkg: error processing /var/cache/apt/archives/python2.7_2.7.3-6+deb7u4_armhf.deb (--unpack):
trying to overwrite '/usr/share/menu', which is also in package pcmanfm 1.2.3-1+raspi
Preparing to replace python3.2 3.2.3-7 (using .../python3.2_3.2.3-7+deb7u1_armhf.deb) ...
Unpacking replacement python3.2 ...
dpkg: error processing /var/cache/apt/archives/python3.2_3.2.3-7+deb7u1_armhf.deb (--unpack):
Unpacking libexpat1-dev (from .../libexpat1-dev_2.1.0-1+deb7u5_armhf.deb) ...
dpkg: error processing /var/cache/apt/archives/libexpat1-dev_2.1.0-1+deb7u5_armhf.deb (--unpack):
trying to overwrite '/usr/share/doc-base', which is also in package findutils 4.4.2-4
Processing triggers for man-db ...
Processing triggers for desktop-file-utils ...
Processing triggers for menu ...
Errors were encountered while processing:
Can anyone help ?
Re: Problem during sudo apt-get dist-upgrade (Pi B+)
Posted: Tue Dec 26, 2017 7:46 am
by fruitoftheloom
Suggested packages:
libexpat1-dev
python2.7 python3.2
Can anyone help ?
You need to synch the repositories first with update in Raspbian
sudo apt-get update
sudo reboot
What Raspbian release are you running ??
Posted: Tue Dec 26, 2017 10:56 am
by KevF
Thanks for your quick reply.
I'm running Linux raspberrypi 3.12.35+ #730 PREEMPT Fri Dec 19 18:31:24 GMT 2014 armv6l
I tried sudo apt-get update before sudo apt-get dist-upgrade but got the same messages:
$ sudo apt-get dist-upgrade
I then tried a reboot followed by sudo apt-get -f dist-upgrade which retrieved a lot of files and seemed to be working but then stopped with -
Preparing to replace libc-bin 2.13-38+rpi2+deb7u3 (using .../libc-bin_2.13-38+rpi2+deb7u12_armhf.deb) ...
Unpacking replacement libc-bin ...
dpkg: error processing /var/cache/apt/archives/libc-bin_2.13-38+rpi2+deb7u12_armhf.deb (--unpack):
trying to overwrite '/usr/share/man/man5', which is also in package ncurses-bin 5.9-10
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
E: Sub-process /usr/bin/dpkg returned an error code (1)
I'd prefer not to have to re-image if at all possible as I recall it took me a while to get the wifi configuration set-up and working
I'm running headless over putty if that makes any difference
Posted: Tue Dec 26, 2017 1:14 pm
by beta-tester
isn't it better to do an upgrade first, to upgrade all installed packages of your current installed raspbian-wheezy
befor doing a distribution upgrade to the new raspbian-stretch via dist-upgrade?
sudo apt-get update
sudo apt-get upgrade
sudo reboot
and then if you still want to upgrade to a new distribution (raspbian-stretch) do
but you maybe have screwed up your installation already... :?
did you only wanted to upgrade the packages only or did you tried to upgrade to a new distribution?
when you have a second sd card, then start with that and a fresh installation. setting up wifi on raspbian-stretch is easier then it was two distributions befor on raspbian-wheezy i think.
BTW: stupid question... is your file system expanded to the whole SD card?
i think under the old raspbian wheezy, you have to expand the file system by hand first to have enough space (via using raspi-config)
Posted: Tue Dec 26, 2017 4:53 pm
by KevF
Hi beta,
I tried update then upgrade, reboot and then dist-upgrade but still same issues
TBH I only wanted to update my python / GPIO related packages but read somehwere online about doing the dist-upgrade so tried that. So looks like the installation is perma-messed :-( !
Checked raspi-config re. expanding and got a message about partition layout not being supported but probs running NOOBS which is fully expanded anyway
Unless anyone has any better suggestions I'll go hunting for another sd card and try a fresh install
Posted: Tue Dec 26, 2017 7:04 pm
by beta-tester
next time, if you simply want to update a single package then you can use
sudo apt-get update
sudo apt-get install --only-upgrade python
(for upgrade python only)
BTH: i think you can't make your installation even worse...
try to install the missing package by hand
sudo apt-get install libexpat1-dev
or use more advances options to fix the installation, remove and clean up unused packages
sudo apt-get install --fix-broken --fix-missing
sudo apt-get autoremove --purge
sudo apt-get autoclean
sudo apt-get clean
you can also try to reinstall the packages with combination of fix...
sudo apt-get install --reinstall --fix-broken --fix-missing libc-bin
sudo apt-get install --reinstall --fix-broken --fix-missing python
sudo apt-get install --reinstall --fix-broken --fix-missing python2.7
sudo apt-get install --reinstall --fix-broken --fix-missing python3.2
but i am wondering, why you get errors while umpacking.
Posted: Tue Dec 26, 2017 7:25 pm
by KevF
ok thanks - I'll persevere a bit longer (always prefer trying to fix things rather than throwing them out and buying new !)
I'll post how I get on
Cheers
Posted: Tue Dec 26, 2017 7:41 pm
by DougieLawson
Try installing synaptic or aptitude and using one of those tools to resolve all of your broken packages.
Posted: Wed Dec 27, 2017 3:43 pm
by KevF
Thanks guys but gave up on the repair / fix-it option after trying all above suggestions and getting very confused in the aptitude text gui !
Tried to install synaptic but ran into similar errors and aborted.
I have now installed Rasbian Stretch and wifi setup went smoothly
Cheers for efforts
