Analog Reads from SCT-013 current sensor using MCP3008
Posted: Sat Dec 23, 2017 2:39 am
Hi ,
i'm new to Current monitor and analog sensor with Raspberry
i'm using SCT-013 with Raspberry Pi 3 and connected to MCP3008 to read analog input from SCT-013 to calculate the Current Amp , i followed datasheet to wire MCP3008 to Raspberry and SCT-013 connected to CH0 .
i tried Python code mentioned here :
viewtopic.php?t=123962
but i got 1308 mV all the time while i'm connected to 100 Watt lamp and AC 240 V even if the sensor caliper is not connected to Elec. cable !
can you explain to me how to use
