AlexJ
Lock-up with experimental gpu driver (full kms)
Fri Dec 22, 2017 4:48 pm
This is more of a bug report than a troubleshoot request, but because the whole pi locks up I don't really know where to file it.
Basically using xrandr to switch modes followed by mpv to play a file nearly always loks up the pi.
My steps to reproduce (probably not all necessary)
  • Install 2017-11-29-raspbian-stretch.zip
  • Switch to full kms
  • change gpu mem to 256
  • enable ssh
  • connect to wifi
  • ssh in
  • export DISPLAY=:0
  • xrandr --output HDMI-1 --mode 1280x1024
  • wget https://github.com/KanoComputing/kano-v ... ecraft.mp4
  • sudo apt-get install mpv
  • mpv --fs minecraft.mp4 --keepaspect=no
  • xrandr --output HDMI-1 --mode 1920x1080
If it doesn't immediatley lock up, switching back and forth between modes and playing a video each time seems to do so.
This is using an ASUS VS247 monitor.
AlexJ
Re: Lock-up with experimental gpu driver (full kms)
Here is Xorg.0.log in case it is useful
[     6.292]
X.Org X Server 1.19.2
Release Date: 2017-03-02
[     6.292] X Protocol Version 11, Revision 0
[     6.292] Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
[     6.292] Current Operating System: Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
[     6.292] Kernel command line: 8250.nr_uarts=0 cma=256M bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=40876377-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[     6.292] Build Date: 18 October 2017  04:55:30PM
[     6.292] xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
[     6.292] Current version of pixman: 0.34.0
[     6.292] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     6.293] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     6.293] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 29 02:57:33 2017
[     6.295] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     6.297] (==) No Layout section.  Using the first Screen section.
[     6.297] (==) No screen section available. Using defaults.
[     6.297] (**) |-->Screen "Default Screen Section" (0)
[     6.297] (**) |   |-->Monitor "<default monitor>"
[     6.303] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[     6.303] (==) Automatically adding devices
[     6.303] (==) Automatically enabling devices
[     6.303] (==) Automatically adding GPU devices
[     6.303] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     6.312] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[     6.312] 	Entry deleted from font path.
[     6.312] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     6.321] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[     6.321] 	Entry deleted from font path.
[     6.328] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[     6.328] 	Entry deleted from font path.
[     6.328] (==) FontPath set to:
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	built-ins
[     6.328] (==) ModulePath set to "/usr/lib/xorg/modules"
[     6.328] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[     6.331] (II) Loader magic: 0x1fbf40
[     6.331] (II) Module ABI versions:
[     6.331] 	X.Org ANSI C Emulation: 0.4
[     6.331] 	X.Org Video Driver: 23.0
[     6.331] 	X.Org XInput driver : 24.1
[     6.331] 	X.Org Server Extension : 10.0
[     6.334] (++) using VT number 7
[     6.334] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     6.337] (II) xfree86: Adding drm device (/dev/dri/card0)
[     6.339] (II) no primary bus or device found
[     6.339] 	falling back to /sys/devices/platform/soc/soc:gpu/drm/card0
[     6.340] (II) LoadModule: "glx"
[     6.343] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     6.423] (II) Module glx: vendor="X.Org Foundation"
[     6.423] 	compiled for 1.19.2, module version = 1.0.0
[     6.423] 	ABI class: X.Org Server Extension, version 10.0
[     6.423] (==) Matched modesetting as autoconfigured driver 0
[     6.423] (==) Matched fbdev as autoconfigured driver 1
[     6.423] (==) Assigned the driver to the xf86ConfigLayout
[     6.423] (II) LoadModule: "modesetting"
[     6.425] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     6.430] (II) Module modesetting: vendor="X.Org Foundation"
[     6.430] 	compiled for 1.19.2, module version = 1.19.2
[     6.430] 	Module class: X.Org Video Driver
[     6.430] 	ABI class: X.Org Video Driver, version 23.0
[     6.430] (II) LoadModule: "fbdev"
[     6.430] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[     6.432] (II) Module fbdev: vendor="X.Org Foundation"
[     6.432] 	compiled for 1.19.0, module version = 0.4.4
[     6.432] 	Module class: X.Org Video Driver
[     6.432] 	ABI class: X.Org Video Driver, version 23.0
[     6.432] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     6.432] (II) FBDEV: driver for framebuffer: fbdev
[     6.458] (II) modeset(0): using drv /dev/dri/card0
[     6.458] (WW) Falling back to old probe method for fbdev
[     6.458] (II) Loading sub module "fbdevhw"
[     6.458] (II) LoadModule: "fbdevhw"
[     6.458] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     6.461] (II) Module fbdevhw: vendor="X.Org Foundation"
[     6.461] 	compiled for 1.19.2, module version = 0.0.2
[     6.461] 	ABI class: X.Org Video Driver, version 23.0
[     6.461] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[     6.461] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     6.461] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[     6.461] (==) modeset(0): RGB weight 888
[     6.462] (==) modeset(0): Default visual is TrueColor
[     6.462] (II) Loading sub module "glamoregl"
[     6.462] (II) LoadModule: "glamoregl"
[     6.462] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     6.516] (II) Module glamoregl: vendor="X.Org Foundation"
[     6.517] 	compiled for 1.19.2, module version = 1.0.0
[     6.517] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     6.517] (II) glamor: OpenGL accelerated X.org driver based.
[     7.861] (II) glamor: EGL version 1.4 (DRI2):
[     7.934] (II) modeset(0): glamor initialized
[     7.974] (II) modeset(0): Output HDMI-1 has no monitor section
[     7.975] (II) modeset(0): Output Composite-1 has no monitor section
[     7.975] (II) modeset(0): Output DSI-1 has no monitor section
[     8.015] (II) modeset(0): EDID for output HDMI-1
[     8.015] (II) modeset(0): Manufacturer: ACI  Model: 249a  Serial#: 2322
[     8.016] (II) modeset(0): Year: 2012  Week: 36
[     8.016] (II) modeset(0): EDID Version: 1.3
[     8.016] (II) modeset(0): Digital Display Input
[     8.016] (II) modeset(0): Max Image Size [cm]: horiz.: 52  vert.: 29
[     8.016] (II) modeset(0): Gamma: 2.20
[     8.016] (II) modeset(0): DPMS capabilities: Off
[     8.016] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     8.016] (II) modeset(0): First detailed timing is preferred mode
[     8.016] (II) modeset(0): redX: 0.641 redY: 0.338   greenX: 0.311 greenY: 0.619
[     8.016] (II) modeset(0): blueX: 0.159 blueY: 0.059   whiteX: 0.313 whiteY: 0.329
[     8.016] (II) modeset(0): Supported established timings:
[     8.016] (II) modeset(0): [email protected]
[     8.017] (II) modeset(0): [email protected]
[     8.017] (II) modeset(0): Manufacturer's mask: 0
[     8.017] (II) modeset(0): Supported standard timings:
[     8.017] (II) modeset(0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[     8.017] (II) modeset(0): #1: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[     8.017] (II) modeset(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     8.017] (II) modeset(0): #3: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     8.017] (II) modeset(0): #4: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     8.017] (II) modeset(0): #5: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[     8.017] (II) modeset(0): #6: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[     8.017] (II) modeset(0): #7: hsize: 1280  vsize 800  refresh: 60  vid: 129
[     8.017] (II) modeset(0): Supported detailed timing:
[     8.017] (II) modeset(0): clock: 148.5 MHz   Image Size:  521 x 293 mm
[     8.017] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     8.018] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     8.018] (II) modeset(0): Serial No: C9LMTF002322
[     8.018] (II) modeset(0): Ranges: V min: 50 V max: 75 Hz, H min: 24 H max: 83 kHz, PixClock max 175 MHz
[     8.018] (II) modeset(0): Monitor name: ASUS VS247
[     8.018] (II) modeset(0): Supported detailed timing:
[     8.018] (II) modeset(0): clock: 27.0 MHz   Image Size:  521 x 293 mm
[     8.018] (II) modeset(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[     8.018] (II) modeset(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[     8.018] (II) modeset(0): clock: 74.2 MHz   Image Size:  521 x 293 mm
[     8.018] (II) modeset(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[     8.018] (II) modeset(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[     8.018] (II) modeset(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[     8.019] (II) modeset(0): h_active: 720  h_sync: 732  h_sync_end 796 h_blank_end 864 h_border: 0
[     8.019] (II) modeset(0): v_active: 576  v_sync: 581  v_sync_end 586 v_blanking: 625 v_border: 0
[     8.019] (II) modeset(0): Number of EDID sections to follow: 1
[     8.019] (II) modeset(0): EDID (in hex):
[     8.019] (II) modeset(0): 	00ffffffffffff0004699a2412090000
[     8.019] (II) modeset(0): 	2416010380341d782a2ac5a4564f9e28
[     8.019] (II) modeset(0): 	0f5054b7ef00714f814081809500b300
[     8.019] (II) modeset(0): 	d1c081c08100023a801871382d40582c
[     8.019] (II) modeset(0): 	450009252100001e000000ff0043394c
[     8.019] (II) modeset(0): 	4d54463030323332320a000000fd0032
[     8.019] (II) modeset(0): 	4b185311000a202020202020000000fc
[     8.019] (II) modeset(0): 	00415355532056533234370a202001f1
[     8.019] (II) modeset(0): 	020322714f0102031112130414050e0f
[     8.019] (II) modeset(0): 	1d1e1f10230917078301000065030c00
[     8.019] (II) modeset(0): 	10008c0ad08a20e02d10103e96000925
[     8.020] (II) modeset(0): 	21000018011d007251d01e206e285500
[     8.020] (II) modeset(0): 	09252100001e011d00bc52d01e20b828
[     8.020] (II) modeset(0): 	554009252100001e8c0ad09020403120
[     8.020] (II) modeset(0): 	0c405500092521000018000000000000
[     8.020] (II) modeset(0): 	0000000000000000000000000000005d
[     8.020] (II) modeset(0): Printing probed modes for output HDMI-1
[     8.020] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     8.020] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.020] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     8.021] (II) modeset(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[     8.021] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[     8.021] (II) modeset(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[     8.021] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     8.021] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     8.021] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.021] (II) modeset(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     8.021] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     8.021] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     8.021] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     8.021] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.021] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     8.021] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.021] (II) modeset(0): Modeline "1440x576"x50.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.022] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     8.022] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     8.022] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.022] (II) modeset(0): Modeline "1440x480"x60.0   54.05  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.022] (II) modeset(0): Modeline "1440x480"x59.9   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.022] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     8.022] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     8.022] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     8.022] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.022] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     8.022] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.022] (II) modeset(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.022] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.022] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     8.023] (II) modeset(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     8.023] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.023] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.023] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     8.023] (II) modeset(0): EDID for output Composite-1
[     8.023] (II) modeset(0): Printing probed modes for output Composite-1
[     8.023] (II) modeset(0): Modeline "720x480"x31.3   13.50  720 734 798 858  480 483 486 502 interlace (15.7 kHz e)
[     8.023] (II) modeset(0): EDID for output DSI-1
[     8.023] (II) modeset(0): Output HDMI-1 connected
[     8.024] (II) modeset(0): Output Composite-1 disconnected
[     8.024] (II) modeset(0): Output DSI-1 disconnected
[     8.024] (II) modeset(0): Using exact sizes for initial modes
[     8.024] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[     8.024] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.024] (==) modeset(0): DPI set to (96, 96)
[     8.024] (II) Loading sub module "fb"
[     8.024] (II) LoadModule: "fb"
[     8.025] (II) Loading /usr/lib/xorg/modules/libfb.so
[     8.032] (II) Module fb: vendor="X.Org Foundation"
[     8.032] 	compiled for 1.19.2, module version = 1.0.0
[     8.032] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.032] (II) UnloadModule: "fbdev"
[     8.032] (II) Unloading fbdev
[     8.033] (II) UnloadSubModule: "fbdevhw"
[     8.033] (II) Unloading fbdevhw
[     8.033] (==) Depth 24 pixmap format is 32 bpp
[     8.378] (==) modeset(0): Backing store enabled
[     8.378] (==) modeset(0): Silken mouse enabled
[     8.382] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[     8.387] (==) modeset(0): DPMS enabled
[     8.387] (II) modeset(0): [DRI2] Setup complete
[     8.387] (II) modeset(0): [DRI2]   DRI driver: vc4
[     8.387] (II) modeset(0): [DRI2]   VDPAU driver: vc4
[     8.387] (--) RandR disabled
[     8.416] (II) SELinux: Disabled on system
[     8.423] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[     8.423] (II) AIGLX: enabled GLX_ARB_create_context
[     8.423] (II) AIGLX: enabled GLX_ARB_create_context_profile
[     8.423] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[     8.423] (II) AIGLX: enabled GLX_INTEL_swap_event
[     8.423] (II) AIGLX: enabled GLX_SGI_swap_control
[     8.423] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[     8.423] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[     8.423] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[     8.423] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[     8.426] (II) AIGLX: Loaded and initialized vc4
[     8.426] (II) GLX: Initialized DRI2 GL provider for screen 0
[     8.435] (II) modeset(0): Damage tracking initialized
[     8.436] (II) modeset(0): Setting screen physical size to 508 x 285
[     8.660] (II) config/udev: Adding input device Kano Keyboard (/dev/input/event0)
[     8.660] (**) Kano Keyboard: Applying InputClass "libinput keyboard catchall"
[     8.661] (II) LoadModule: "libinput"
[     8.661] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.685] (II) Module libinput: vendor="X.Org Foundation"
[     8.686] 	compiled for 1.19.0, module version = 0.23.0
[     8.686] 	Module class: X.Org XInput Driver
[     8.686] 	ABI class: X.Org XInput driver, version 24.1
[     8.686] (II) Using input driver 'libinput' for 'Kano Keyboard'
[     8.686] (**) Kano Keyboard: always reports core events
[     8.686] (**) Option "Device" "/dev/input/event0"
[     8.686] (**) Option "_source" "server/udev"
[     8.688] (II) input device 'Kano Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[     8.688] (II) input device 'Kano Keyboard', /dev/input/event0 is a keyboard
[     8.760] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1997:2433.0001/input/input0/event0"
[     8.760] (II) XINPUT: Adding extended input device "Kano Keyboard" (type: KEYBOARD, id 6)
[     8.760] (**) Option "xkb_model" "pc105"
[     8.760] (**) Option "xkb_layout" "gb"
[     8.835] (II) input device 'Kano Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[     8.835] (II) input device 'Kano Keyboard', /dev/input/event0 is a keyboard
[     8.838] (II) config/udev: Adding input device Kano Keyboard (/dev/input/event1)
[     8.838] (**) Kano Keyboard: Applying InputClass "libinput pointer catchall"
[     8.838] (**) Kano Keyboard: Applying InputClass "libinput keyboard catchall"
[     8.838] (II) Using input driver 'libinput' for 'Kano Keyboard'
[     8.838] (**) Kano Keyboard: always reports core events
[     8.838] (**) Option "Device" "/dev/input/event1"
[     8.838] (**) Option "_source" "server/udev"
[     8.840] (II) input device 'Kano Keyboard', /dev/input/event1 is tagged by udev as: Keyboard Mouse
[     8.840] (II) input device 'Kano Keyboard', /dev/input/event1 is a pointer caps
[     8.840] (II) input device 'Kano Keyboard', /dev/input/event1 is a keyboard
[     8.880] (II) libinput: Kano Keyboard: needs a virtual subdevice
[     8.880] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input1/event1"
[     8.880] (II) XINPUT: Adding extended input device "Kano Keyboard" (type: MOUSE, id 7)
[     8.881] (**) Option "AccelerationScheme" "none"
[     8.881] (**) Kano Keyboard: (accel) selected scheme none/0
[     8.881] (**) Kano Keyboard: (accel) acceleration factor: 2.000
[     8.881] (**) Kano Keyboard: (accel) acceleration threshold: 4
[     8.883] (II) input device 'Kano Keyboard', /dev/input/event1 is tagged by udev as: Keyboard Mouse
[     8.883] (II) input device 'Kano Keyboard', /dev/input/event1 is a pointer caps
[     8.883] (II) input device 'Kano Keyboard', /dev/input/event1 is a keyboard
[     8.885] (II) config/udev: Adding input device Kano Keyboard (/dev/input/mouse0)
[     8.885] (II) No input driver specified, ignoring this device.
[     8.885] (II) This device may have been added with another device file.
[     8.898] (**) Kano Keyboard: Applying InputClass "libinput pointer catchall"
[     8.898] (**) Kano Keyboard: Applying InputClass "libinput keyboard catchall"
[     8.898] (II) Using input driver 'libinput' for 'Kano Keyboard'
[     8.898] (**) Kano Keyboard: always reports core events
[     8.898] (**) Option "Device" "/dev/input/event1"
[     8.898] (**) Option "_source" "_driver/libinput"
[     8.898] (II) libinput: Kano Keyboard: is a virtual subdevice
[     8.898] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input1/event1"
[     8.898] (II) XINPUT: Adding extended input device "Kano Keyboard" (type: KEYBOARD, id 8)
[     8.898] (**) Option "xkb_model" "pc105"
[     8.898] (**) Option "xkb_layout" "gb"
[    13.175] (II) modeset(0): Disabling kernel dirty updates, not required.
[   150.346] (II) modeset(0): EDID vendor "ACI", prod id 9370
[   150.347] (II) modeset(0): Using EDID range info for horizontal sync
[   150.347] (II) modeset(0): Using EDID range info for vertical refresh
[   150.347] (II) modeset(0): Printing DDC gathered Modelines:
[   150.347] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[   150.347] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   150.347] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   150.347] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   150.347] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   150.348] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   150.348] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   150.348] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   150.348] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   150.348] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   150.348] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   150.348] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   150.348] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   150.348] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   150.348] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   150.348] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   150.348] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   150.348] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   150.349] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   150.349] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   150.349] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   150.349] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[   150.349] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[   150.349] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   150.349] (II) modeset(0): Modeline "1280x720"x60.0   74.48  1280 1336 1472 1664  720 721 724 746 -hsync +vsync (44.8 kHz e)
[   150.349] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[   150.349] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[   150.349] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[   150.349] (II) modeset(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[   150.349] (II) modeset(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[   150.349] (II) modeset(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   150.349] (II) modeset(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   150.349] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   150.350] (II) modeset(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
