muth
Booting Error with Debian Wheezy
Mon Oct 15, 2012 6:41 am
I have some booting problems with the soft-float debian wheezy image.
I have the rev1 board. When I first boot the system with a fresh image on the SD, everything is fine, boot, setup, X...
But if I shut down the system (with and without 'sudo halt') and restart, it boot until to put the raspberry on the top of the screen and stop without print any text. I connected to the serial console and got :
[    1.800928] Initializing XFRM netlink socket
[    1.805233] NET: Registered protocol family 17
[    1.809995] Registering the dns_resolver key type
[    1.816925] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
ø[    1.839912] Waiting for root device /dev/mmcblk0p2...
[    1.893745] mmc0: problem reading SD Status register.
[    1.916664] mmc0: new high speed SDHC card at address e624
[    1.926631] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[    1.938435]  mmcblk0: p1 p2
[    2.059447] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    2.067848] List of all partitions:
[    2.071393] b300         7761920 mmcblk0  driver: mmcblk
[    2.076890]   b301           57344 mmcblk0p1 00000000-0000-0000-0000-000000000000
[    2.084402]   b302         1832960 mmcblk0p2 00000000-0000-0000-0000-000000000000
[    2.091947] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: c059e4e8
[    2.091961]
[    2.102227] [<c0015050>] (unwind_backtrace+0x0/0xfc) from [<c03ec104>] (dump_stack+0x20/0x24)
[    2.110829] [<c03ec104>] (dump_stack+0x20/0x24) from [<c03ec27c>] (panic+0x74/0x1ac)
[    2.118642] [<c03ec27c>] (panic+0x74/0x1ac) from [<c002e514>] (__stack_chk_fail+0x20/0x24)
[    2.126978] [<c002e514>] (__stack_chk_fail+0x20/0x24) from [<c059e4e8>] (printk_all_partitions+0x1fc/0x234)
[    2.136799] [<c059e4e8>] (printk_all_partitions+0x1fc/0x234) from [<c058dc9c>] (mount_block_root+0x198/0x250)
[    2.146806] [<c058dc9c>] (mount_block_root+0x198/0x250) from [<c058df3c>] (mount_root+0xc4/0xec)
[    2.155619] [<c058df3c>] (mount_root+0xc4/0xec) from [<c058e0c8>] (prepare_namespace+0x164/0x1c4)
[    2.164554] [<c058e0c8>] (prepare_namespace+0x164/0x1c4) from [<c058d8e8>] (kernel_init+0xf8/0x124)
[    2.173674] [<c058d8e8>] (kernel_init+0xf8/0x124) from [<c000f020>] (kernel_thread_exit+0x0/0x8)
PANIC: stack-protector: Kernel stack is corrupted in: c059e4e8
Entering kdb (current=0xc0849020, pid 1) due to Keyboard Entry
kdb>
I tryed to re-size the partition, an other SD card, always the same. I can reboot with the command line, but I cannot shutdown and restart.
I have no problem with the hard-float raspibian with the same SD card.
Is someone have the same problem or can advise me ? I'm not really confident with boot level of linux.
Thanks a lot
ptihackers
Re: Booting Error with Debian Wheezy
Sun Dec 23, 2012 5:54 am
I'm getting the error with RPi model B and soft-float debian wheezy image.
Thanks.
