Lukas86
RPi doesn't boot after editing /boot/cmdline.txt
Sat Dec 16, 2017 8:22 pm
I tried to disable screen blanking by adding
consoleblank=0
to the end of the line in
/boot/cmdline.txt.
Since then the Raspberry doesn't seem to boot completely. I can see in the screen that the boot process is starting but then the screen turns off and nothing else happens.
Now I don't even now how to undo my changes as I cannot get access to the raspberry.
Any help is highly appreciated. I'm a beginner and I am using the raspberry in a christmas present, I am feeling quite helpless right now... :(
Thank you,
Lukas
DirkS
Re: RPi doesn't boot after editing /boot/cmdline.txt
Sat Dec 16, 2017 9:09 pm
I assume you still have physical access to the pi?
If so, the take out the card and put it in any computer. You should see the file cmdline.txt
Use a text editor to undo your changes.
NB: make sure that everything in this file is on a single line
Lukas86
Sun Dec 17, 2017 3:11 pm
Thanks, that worked! But I still don't know why this was wrong. In several tutorials it is written that you can add consoleblank=0 to that line (yes, it was one single line) to disable screensaver. Does it have to be in a specfic position?
Anyway, thanky for your help. At least everything is running again.
n67
Sun Dec 17, 2017 3:14 pm
You will need to post your exact cmdline.txt file here (after you made your change) in order for us to ascertain what you did wrong...
My guess is a missing space or something like that.
Lukas86
Sun Dec 17, 2017 3:36 pm
Here is the complete line:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=51df20e4-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles consoleblank=0
bensimmo
Sun Dec 17, 2017 5:56 pm
https://www.raspberrypi.org/documentati ... ensaver.md
That's the way to do it.
Check you never pressed return at the end for a new line?
Who is online
Users browsing this forum: Google [Bot] and 62 guests
