notrum1234
Raspberry Pi Headless - Wireless
Fri Dec 15, 2017 5:03 pm
Hi all,
I'm trying to get my rpi zero v1.2 installed with a headless install, then automatically connecting to the wifi. I've got rpi's up and running easily before however my pi just won't connect to the wifi?
I've followed tutorials on how to set up this up including:
- Creating a the bootable usb - (Raspbian Stretch Lite - Nov release)
- Creating a blank ssh file into the boot root
- Create a wpa_supplicant.conf file in the root. Using this config. My wireless is a WPA2-PSK. In the UK.
update_config=1
country=GB
network={
	ssid="BTHub*****"
	psk="**********"
	key_mgmt=WPA-PSK
Is there something I'm missing? Any pointers would really appreciated, been trying for many hours!
wh7qq
Re: Raspberry Pi Headless - Wireless
Sat Dec 16, 2017 8:09 pm
Sent by WH7QQ from an RPi3/Raspbian/pixel desktop.
HawaiianPi
Sun Dec 17, 2017 10:41 am
Hi all,
Are you trying to boot from a USB flash drive without an SD card? If so, you first have to boot with an SD card with a special entry in config.txt to enable USB boot. https://github.com/raspberrypi/document ... des/msd.md
davidcoton
Sun Dec 17, 2017 11:53 am
Hi all,
It's a Pi Zero -- it doesn't do USB only boot. The problem seems to be the WiFi only, not the boot. What is in the file /etc/wpa_supplicant/wpa_supplicant.conf? For Stretch, it should be:
update_config=1
country=GB
network={
    ssid="testing"
    psk="testingPassword"
but with your own country code, ssid and password.
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
Who is online
Users browsing this forum: PhatFil and 31 guests
