Still learning and made the mistake of changing fstab without having a backup. Running latest raspbian.
When booted gets stuck in a loop of "Cannot access console, press enter to continue."
My guess is I need to access the fstab file and remove the changes but how can I do this with no access to the console?
Screenshot: https://imgur.com/a/DuoHM
Thanks in advance.
Re: Edited fstab, rebooted, Cannot access to console, the root account is locked
Well, sorry for that.
Add init=/bin/sh to cmdline.txt and sweat your way out of it
viewtopic.php?t=172814
Fixed! Thanks for the help
I'm having the same issue but adding the init=/bin/sh makes no difference. Anything else I can try?
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Toss the SDCard and write a new one.
When I tried it the "init=/bin/sh" had to be on the second line not on a new line and also in quotes. Else it seemed to do nothing.
Think about it!ZigzagoonBalloon wrote: ↑Mon Dec 04, 2017 11:08 pmWhen I tried it the "init=/bin/sh" had to be on the second line not on a new line and also in quotes. Else it seemed to do nothing.
cmdline.txt contains the command line arguments that are passed to the linux kernel when it starts up.
cmdline.txt should obviously only contain one single line of text.
Just add init=/bin/bash somewhere within the line or at the end.
Tried everything, but non worked. Your solution helped get access to the console. However I had to add nofail to make it worked.
Hello All,
I am getting the same issue. I know what I did wrong I just cannot get back in to fix it. After the Pi boots I get the Press enter to continue message but when I click enter it does not continue. Can someone please tell me what I am doing wrong.
Cyteck2000
Cyteck2000
What is amazing is that when you hit Enter, the operating system is capable of fixing the lock and continuing with boot up.
Which says the Raspbian people really don't want you running their OS unattended. They don't give a flying about headless.
No, they want you right there in attendance for every boot. Don't go away. Wait for it. Wait for it. OK, now you can go.
- DougieLawson
Poppycock and balderdash. That's the best piece of complete nonsense I've read all day. All fifteen of my raspberries run completely headless.mrmsbarnes wrote: ↑Mon Jul 16, 2018 5:44 amWhat is amazing is that when you hit Enter, the operating system is capable of fixing the lock and continuing with boot up.
- Yukon Cornelius
Don't be too hasty in judgement ..... it's still early and it's a Monday .....DougieLawson wrote: ↑Mon Jul 16, 2018 7:14 am....... That's the best piece of complete nonsense I've read all day. .....
But seriously , backing-up the sd card is so easy .
I use the dd command in Linux , or you can use Etcher , if a GUI is preferred .
It works beautifully in both Linux and " that other OS " .
Either way , there's no sensible reason not to make back-ups , then you can bork away to your heart's content
PS : I think I read somewhere that Raspbian now has it's own writer built-in
It showed this issue after i disconnect the boot disk drive and plugged into Mac, then mac created .DS_Store file in this disk, after deleted all those .DS_Store files, reconnect to raspi, it works without any issue.
