Mincerafte
Major Startx problem
Thu Nov 23, 2017 8:27 pm
Ok, so I was trying to change the operating system from Wheezy to Jessie, and I input the commands on this website:
https://www.howtoforge.com/tutorial/how ... e-release/
And after I did:
apt-get dist-upgrade
There was an error that I can't reference, but this resulted in startx being unusable, because "server x is unavailable." Being the idiot I am, I tried to change the config settings to go directly to desktop instead of logging in, but now it's a never-ending black screen. I had it on for an hour, and it was always a black screen. Now I can't input any commands at all. Help!
What? What do you mean it's outdated? I swear it was fine a while ago...
The Traveler
Re: Major Startx problem
Fri Nov 24, 2017 4:03 am
Reburn your sdcard with the newer distro version. The easiest way to fix it.
Cheers.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
sora03
Fri Nov 24, 2017 10:23 am
And after I did:
the commands to upgrade is to upgrade wheezy first by $ sudo apt-get upgrade then add the jessie repo then $ sudo apt-get update then $ sudo apt-get dist-upgrade
but distro upgrades are prone to error such as missing packages or old configuration so you should just download jessie (we are now using stretch) and burn it to a microsd/sd card
FLOSS enthusiast, Debian user (linux-libre)
Mincerafte
Fri Nov 24, 2017 4:15 pm
So y'all are saying I need to clear everything?
The Traveler
Fri Nov 24, 2017 5:20 pm
Yep.
I don't discourage anyone from learning Linux, (and fixing a failed upgrade WOULD be a learning experience) but if you would rather mess around with programming your RPi than fixing OS problems, a new image is much more expedient.
Cheers.
Mincerafte
Fri Nov 24, 2017 6:21 pm
Alright then. Thank you!
