trnolen09
Model 3 B will not start up
Thu Nov 23, 2017 4:02 pm
Hey I recently bought the Raspberry Pi 3 Model B and I am having some problems getting it to boot. I started it up last night and did the initial install and everything appeared to work fine. This morning I fired it up and everything showed up on the screen like normal. I had the IO plugged into the breadboard and was using the 5v power supply to light up an led in a simple resistor and led circuit and when I looked up at the screen I noticed that the screen had shut off. My activity light was off and it was no longer reading from the SD card. I figured out that the cpu chip is hot and when I try to boot it again it will overheat in a matter of 10 -15 seconds and will not boot. It was working fine last night and suddenly nothing. Any suggestions?
HawaiianPi
Re: Model 3 B will not start up
Thu Nov 23, 2017 8:06 pm
If your resistor value was wrong you may have fried the SoC (CPU). The Pi GPIO is 3.3V and is not tolerant of more. Connecting 5V to the GPIO will damage the SoC.
trnolen09
Fri Nov 24, 2017 4:20 am
Thanks. I had to have done something wrong just not sure what exactly at this point.
sora03
Fri Nov 24, 2017 10:21 am
the Pi's gpio is 3v3 powered you should not connect them with the 5v power pins. Does the Red and green LED still work? I do not know if Pi3 has a polyfuse but you should wait for days before powering it up wait for the polyfuse to heal
FLOSS enthusiast, Debian user (linux-libre)
Burngate
Fri Nov 24, 2017 11:09 am
Yes it does. MF-MSMF250/X.
