robmcc83
External hard drive unmounts then remounts.
Tue Nov 21, 2017 9:41 pm
Hi every one.
This is the first time I've had to come to this forum and ask for help lol.
Usually managed to find the help I need with all my other projects but this one has got me.
I am using a pi3 as a plex server since buying a new smart tv and being able to use plex on it I thought it would be a good idea.
Now I have got everything working but seem to have problems with the external hdd unmounting then remounting.
I have only the the hard drive plugged into the pi and the hard drive is a 3.5" in a external caddy which is powered by it's own source.
I use the official 5.1v 2.5a plug for the pi.
Now here's how the problem goes.
Can watch a film from the pi to my tv seems ok, I go onto the computer to transfer some over through my network and that's when it unmount.
I have edited fstab to automont in /mnt/library but when it remounts it mounts to media/pi/[label of drive] so I have to reboot the pi for it to mount back where I want it.
This is intermittent I ripped aload of the kids Disney dvds to my computer and then started copying them over network via samba first time happened around 40 seconds into it then drive unmounted.
So rebooted tried again. I managed to copy of 4 movies no problems 5th one drive uncounted again.
So of I went to use winscp and had the same problems.
I'm at a loss as most posts point to not enough power but my hdd has it's own power source
epoch1970
Re: External hard drive unmounts then remounts.
Wed Nov 22, 2017 2:50 pm
The drive may unmount and remount for various reasons.
- power starvation is the most common but in your case, it doesn't seem to apply
- data link reset is another possible cause. It could apply to you. If a read or write fails, due to a defect in the disk (or the controller) the system will retry a few times and if the error remains it resets the data (SCSI/SATA) link. At that moment the USB link is reset and the mount becomes stale. Then the device comes back on line and a "new" USB device is discovered (and mounted elsewhere.)
If you experience link resets when reading or writing, you should see traces in /var/log/syslog. In general when you get link resets and all cables are properly connected, it means your HDD is dying of old age. So you may want to check how your HDD behaves when you connect it to another computer and write heavily to it.
Then there is a possibility the USB-SATA bridge doesn't work as expected under linux, or the driver requires some options. I think this is harder to debug, so it's better to check that the HDD is ok first.
sora03
Thu Nov 23, 2017 12:49 pm
try to check the USB cable to HDD and Pi. set the Pi configuration to max_usb_current. The 3.5" HDD is externally powered so this should not be a problem. Also check the S.M.A.R.T status of the disk
FLOSS enthusiast, Debian user (linux-libre)
epoch1970
Thu Nov 23, 2017 2:46 pm
AFAIK specifying max_usb_current changes nothing on Pi 3
Thu Nov 23, 2017 3:44 pm
After a recent update it does nothing on any Pi B+, 2B or 3B. They default to 1.2A now.
robmcc83
Thu Nov 23, 2017 11:07 pm
Ok so after trying to find a solution to this all day I have the most bizarre outcome and I don't even know if it's possible.
I removed the hard drive from the pi and plugged it into my pc. I downloaded seatools for my drive ran all tests and everything passed.
I then began to copy all the files directly to the drive from the pc. No problems what's so ever.
So I plugged it back into my pi with a different usb cable.
I then started to transfer one of our wedding slideshow videos approx 1gb in size and the drive unmouted at 4% transferred through samba grrrrrrr.
Just out of curiosity I plugged in my powered 4 port usb hub which has it's own power supply, plugged the hard drive into that and powered it on. Sudo reboot and it was mounted back where it should be.
I then began transferring the same file over and it worked fine.
So I was like that's odd, and tried copying more stuff over to it waiting for it to happen but to my surprise I've managed to copy over 24.8gb today with out it umounting.
So if that has fixed the problem I have questions.
Why would it perform how it should do plugged into a powered hub when the hard drive has it's own power source which I know works as i copied alot of stuff over directly on pc.
Could this still have anything to do the power source for the pi.
I've never had any coloured squares in the corner.
davidcoton
Thu Nov 23, 2017 11:12 pm
It possibly indicates a problem with the drive's power supply? Anyway, it looks like you have a working (if not ideal) solution.
BTW, the coloured square has been replaced by a lightening bolt symbol.
Signature retired
Aydan
Fri Nov 24, 2017 8:13 am
SInce it's a 3.5" drive, it needs 12V and 5V to operate.
Maybe the 5V regulator in the enclosure is marginal, and when transferring large amounts of data it drops the voltage.
Another possibility would be that the enclosure doesn't have it's own 5V regulator and uses the 5V from the USB, which of course would be problematic if the USB supply drops out. I suppose your PC has a more stable USB power supply than your Pi, and the powered USB hub is more stable than the Pi as well.
Regards
Aydan
robmcc83
Fri Nov 24, 2017 11:14 am
Well come to think of it I've had problems in the past with this pi3.
When I first purchased it I used it for retropie.
I got 2 2x usb to PlayStation so that I could plug in 4 PlayStation controllers.
Plugging them directly into the pi only 2 controllers would work.
This is what made me buy the Belkin 4 port powered hub that I have upon plugging the usb to PlayStation adapter into the hub all 4 controllers worked.
Surely though the pi should have enough power to use 4 PlayStation controllers without the need of a hub.
Have I maybe had a faulty pi or maybe power source from the start because I can't really plug anything more than a keyboard or mouse into it without a hub
Cheers
Fri Nov 24, 2017 12:25 pm
The RPi has 1200mA to spread across 4 USB 2.0 interfaces. If you draw 500mA on four devices you may not have enough left for HDMI, WiFi, BT and the SoC on your Raspberry from a 2500mA supply (watch for the on-display under power lightning bolt). The power budget runs close to overdrawn.
The USB 2.0 spec is 100mA for low power devices, 500mA for high power devices (the device is supposed to report it's requirement as part of the data exchanged during startup). Some don't do that. I've had USB sticks that crash a RPi when you hotplug them. I've got a 32GB USB stick that runs very hot in my laptop, I won't dare to insert that in a running Raspberry.
USB 3.0 spec is 900mA. I don't know how a USB 3.0 device works with a USB 2.0 host for power usage. That must be documented somewhere.
So the recommendation to run your high power USB devices in a powered USB hub is very sensible.
This is a doctor free zone.
