ab1jx
Diagnosing hard crashes, USB drive
Tue Nov 21, 2017 4:34 am
I'm on a Pi 3B running up to date Jessie with a USB hard drive attached which I boot from. With increasing frequency, maybe 10 times today it locks up.
I turned on persistent logging, don't see anything there. Everything stops, if I can see a cursor on the screen it's frozen. I can't ssh to it. I was about to start uninstalling debs in the reverse of the order I installed them in when something occurred to me. If it dies and I can get to a terminal window it can't find anything. I can type halt, shutdown, whatever and the binary won't be found. If I try to shutdown via the GUI menu the desktop file won't be found.
For some reason my USB drive seems to be disconnecting. I've rebooted from an SD card, run fsck on the hard drive, it doesn't find anything and doesn't help. I've unplugged the drive and plugged it back in to clean the connector contacts. I've had it installed about 6 months. It's a Western Digital drive in a Startech case/adapter, both new when I connected them. I don't think it's power because I use an official 2.5 amp supply to run the pi and hard drive, everything else is plugged into a powered hub.
ab1jx
Re: Diagnosing hard crashes, USB drive
Wed Nov 22, 2017 9:47 pm
Ah-hah, caught a failure. I'd just rebooted and went off to do something else, came back to find this before I'd even logged in.
Suggestions?
I'll try it without the RTL2838 dongle plugged in, the problems started roughly the time I plugged that in
Bus 001 Device 008: ID 046d:c077 Logitech, Inc.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x046d Logitech, Inc.
  idProduct          0xc077
  bcdDevice           72.00
  iManufacturer           1 Logitech
  iProduct                2 USB Optical Mouse
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      46
         Report Descriptors:
           ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Bus 001 Device 006: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bda Realtek Semiconductor Corp.
  idProduct          0x2838 RTL2838 DVB-T
  bcdDevice            1.00
  iManufacturer           1 Realtek
  iProduct                2 RTL2838UHIDIR
  iSerial                 3 00000001
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          2
    iConfiguration          4 USB2.0-Bulk&Iso
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              5 Bulk-In, Interface
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bNumConfigurations      2
  (Bus Powered)
Bus 001 Device 011: ID 04b0:0228 Nikon Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x04b0 Nikon Corp.
  idProduct          0x0228
  bcdDevice            1.00
  iManufacturer           1 NIKON
  iProduct                2 NIKON DSC COOLPIX P520-PTP
  iSerial                 3 31008920
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass         6 Imaging
      bInterfaceSubClass      1 Still Image Capture
      bInterfaceProtocol      1 Picture Transfer Protocol (PIMA 15470)
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              16
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    bConfigurationValue     2
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              16
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  (Bus Powered)
Bus 001 Device 009: ID 03f0:5417 Hewlett-Packard
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x03f0 Hewlett-Packard
  idProduct          0x5417
  bcdDevice            1.00
  iManufacturer           1 Hewlett-Packard
  iProduct                2 HP Color LaserJet CP2025dn
  iSerial                 3 00CNGS309277
    bLength                 9
    bDescriptorType         2
    wTotalLength           55
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         7 Printer
      bInterfaceSubClass      1 Printer
      bInterfaceProtocol      2 Bidirectional
      iInterface             18 Printer
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval             255
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface             20 HP EWS
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x0b  EP 11 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval             255
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x8b  EP 11 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Bus 001 Device 007: ID 046d:c31c Logitech, Inc. Keyboard K120 for Business
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idProduct          0xc31c Keyboard K120 for Business
  bcdDevice           64.00
  iProduct                2 USB Keyboard
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    iConfiguration          3 U64.00_B0001
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Keyboard
      iInterface              2 USB Keyboard
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      65
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength     159
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
  (Bus Powered)
Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0610 4-port hub
  bcdDevice           77.32
  iManufacturer           0
  iProduct                1 USB2.0 Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
  wHubCharacteristic 0x00e0
    Ganged power switching
    Ganged overcurrent protection
    TT think time 32 FS bits
    Port indicators
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent    100 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0303 lowspeed power enable connect
   Port 2: 0000.0503 highspeed power enable connect
   Port 3: 0000.0503 highspeed power enable connect
   Port 4: 0000.0100 power
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice           77.32
  iManufacturer           0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
    Port indicators
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 3: 0000.0303 lowspeed power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 010: ID 152d:1562 JMicron Technology Corp. / JMicron USA Technology Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x152d JMicron Technology Corp. / JMicron USA Technology Corp.
  idProduct          0x1562
  bcdDevice           80.34
  iManufacturer           1 JMicron
  iProduct                2 JMS56x Series
  iSerial                 5 DB9876543211166
    bLength                 9
    bDescriptorType         2
    wTotalLength           85
    bNumInterfaces          1
    iConfiguration          4 USB Mass Storage
    bmAttributes         0xc0
      Self Powered
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              6 MSC Bulk-Only Transfer
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           4
      bInterfaceProtocol     98
      iInterface             10 MSC BOT/UAS Transfer
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Command pipe (0x01)
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Status pipe (0x02)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Data-in pipe (0x03)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        Data-out pipe (0x04)
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength           22
  bNumDeviceCaps          2
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000002
      Link Power Management (LPM) Supported
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   1
      Lowest fully-functional device speed is Full Speed (12Mbps)
    bU1DevExitLat          10 micro seconds
    bU2DevExitLat          32 micro seconds
  Self Powered
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x9514
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
    Per-port overcurrent protection
    TT think time 8 FS bits
  bHubContrCurrent      1 milli Ampere
  DeviceRemovable    0x02
 Hub Port Status:
   Port 3: 0000.0100 power
   Port 4: 0000.0503 highspeed power enable connect
   Port 5: 0000.0100 power
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.09
  iManufacturer           3 Linux 4.9.37-v7+ dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 3f980000.usb
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
 Hub Port Status:
  Self Powered
Thu Nov 23, 2017 7:55 am
It looks like you also have a critical failure with your camera as your photo is so out of focus it's unusable.
This is a doctor free zone.
PeterO
Thu Nov 23, 2017 7:59 am
Put your right glasses on Dougie :-) It's quite readable here !
PeterO
sora03
Thu Nov 23, 2017 12:40 pm
the camera picture is out of focus so it is kinda hard to read. Setting that aside, are you sure you have adequate power to the drive? it may appear that the drive randomly disconnects and reconnects to Pi so you are having filesystem errors. Can you also check the S.M.A.R.T status of the drive if there are bad sectors or just bad USB cabling or power supply.
FLOSS enthusiast, Debian user (linux-libre)
ab1jx
Thu Nov 23, 2017 12:52 pm
Hah-hah, I can read it. That's not focus, that's blur. The exposure time was 0.3 seconds because the ISO was set to 200 from using the camera outdoors. It was handheld, I just picked up the camera beside me and shot it.
Meanwhile the Pi is still running with an uptime of 15 hours. I just unplugged my NooElec RTL2832 dongle. Which was plugged into the powered hub, only the hard drive is plugged directly into the Pi. I have 3 of them, I can try a different one. They all receive OK. Can one USB device interfere with another?
Thanks, Peter. I'm trying to do SDR in Motif these days.
ab1jx
Thu Nov 23, 2017 1:27 pm
Wow, smartctl's manpage sure doesn't match what the program says. Anyway I'm not getting anything useful out of it because of the USB layer. smartctl -d ata /dev/sda says it was opened successfully, adding a -a or -x for more information seems to not work.
It's a 320GB laptop drive, how much power could it draw? fsck says it's OK, when I stick in an SD card and boot from that to fsck the hard drive. Only the hard drive and a powered hub are plugged directly into the Pi, which is running on the official 2.5 amp power supply.
I'll see if it can keep running a few days without the RTL2832 dongle.
ab1jx
Thu Nov 23, 2017 2:13 pm
Ah, OK, smartctl -d sat /dev/sda -a worked. Looks OK.
smartctl 6.4 2014-10-07 r4002 [armv7l-linux-4.9.37-v7+] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     ST320LT020-9YG142
Serial Number:    W049WJ6E
LU WWN Device Id: 5 000c50 05c9be83e
Firmware Version: 0003DEM1
User Capacity:    320,072,933,376 bytes [320 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Thu Nov 23 09:08:30 2017 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Status not supported: Incomplete response, ATA output registers missing
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(    0) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (  84) minutes.
Conveyance self-test routine
recommended polling time: 	 (   3) minutes.
SCT capabilities: 	       (0x303f)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   114   099   006    Pre-fail  Always       -       61285600
  3 Spin_Up_Time            0x0003   099   099   085    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1067
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   073   060   030    Pre-fail  Always       -       23785526
  9 Power_On_Hours          0x0032   096   096   000    Old_age   Always       -       4108
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   020    Old_age   Always       -       1067
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       1
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   062   044   045    Old_age   Always   In_the_past 38 (Min/Max 38/41 #1)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       20
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       175
193 Load_Cycle_Count        0x0032   096   096   000    Old_age   Always       -       9530
194 Temperature_Celsius     0x0022   038   056   000    Old_age   Always       -       38 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   057   048   000    Old_age   Always       -       61285600
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       4017 (237 143 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1351021903
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       123213543
250 Read_Error_Retry_Rate   0x0000   001   001   000    Old_age   Offline      -       56276
251 Unknown_Attribute       0x0000   100   001   000    Old_age   Offline      -       553
252 Unknown_Attribute       0x0000   100   001   000    Old_age   Offline      -       1
254 Free_Fall_Sensor        0x0032   001   001   000    Old_age   Always       -       8
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%       544         -
# 2  Short captive       Completed without error       00%       544         -
# 3  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
16:44 uptime now. I've seen this stay up for weeks before I had this problem.
ab1jx
Fri Nov 24, 2017 10:16 pm
Lasted under 24 hours and crashed again. I was away and came back to find it dead.
sora03
Sat Nov 25, 2017 6:53 am
my RPI 2B setup, 1 laptop HDD with Y-USB to miniUSB cable (24AWG 2C /28AWG 1P from a DVD writer) it is plugged to 2 USB port of Pi then to the 3rd port is a webcam generic, and the last port is a usb hub that i hacked to be externally powered. the hub is powered by MP1584 dc buck voltregultor the output is set to 5.3V. the RPi is powered by another MP1584 I have set the output to 5.5v-ish since lower than that I have the same problem as yours the system is unreachable and the Pi's RED led is blinking refers to a low voltage condition (<4.65V) and the HDD disconnects and reconnects leading to command not found errors or I/O errors.
davidcoton
Sat Nov 25, 2017 10:25 am
This is a dangerous solution. If your regulator produces 5.5V, when you shut down and current consumption drops, 5.5V will reach the Pi. This is out of spec and not guaranteed safe. And if you measurement is a bit out, and the voltage drifts up with time or temperature, you could well damage the Pi.
Set the regulator to no more than 5.25V, and use thicker/shorter wires between PSU and Pi.
Signature retired
sora03
Sat Nov 25, 2017 11:42 am
the voltage regulator has a voltage drop that makes the Pi's red led to blink and causing HDD to be disconnected and reconnected. I am using the Power cable (microUSB 20AWG white wire) from the official 2A Pi PSU but that White Pi PSU (5v1 2A) is not sufficient to power my Pi with' HDD and webcam so I just cut the cable and soldered it to a MP1584 voltage regulator. The Pi is never turned off there is also a atiny85 that monitors the Pi's state so when if it is shutdown it will short the RESET pin to reboot the Pi, I also have many peripherals attached to GPIO such as a MQ2 gas sensor (a heater?), the GPIO for 5v shows less than 5.5V when on load, so when the Pi is shutdown it still shows lesser values than in the mp1584 regulator.
ab1jx
Sat Nov 25, 2017 3:48 pm
Nah, I'm not going to fiddle with voltages. This was perfectly stable for months on the official 2.5 amp supply http://www.newark.com/stontronics/t5875 ... dp/77Y6535. Except about the same time we had a couple power outages from tree limbs bringing down wires in the wind, sometimes we get 6 a year. This started crashing after those, probably coincidence.
So I bought a new 12 volt 10 amp hour SLA battery mostly to use with a small solar system. Last summer I picked up a couple of these switching regulator modules https://www.ebay.com/itm/5V-USB-DC-7V-2 ... 1415005496 figuring I'd get more later but now this seller doesn't have them anymore. When I finally got around to trying one it worked fine, I was outdoors with a Pi and camera run by an SLA and the regulator. I'd like to have a few more and use the SLA as a UPS. Haven't got it hooked up yet. I also have a cheap unpowered USB hub which I'd like to power from one of the modules. In a power outage (usually several hours at a time) my cell phone provides internet until its battery goes dead. I need to work on the video monitor running from 12 volts situation.
I have a DrOk inline USB meter and a few DMMs which are OK for spot checks but I don't have anything that does data logging. Maybe the mains does take a dip in voltage, maybe something's arcing over somewhere. The best I could hope to do in the short term is that I picked up a PocketBeagle because it has several A/D inputs. https://www.mouser.com/new/beagleboardo ... RAQAvD_BwE I wanted to use some for monitoring power coming from the solar panels but they could certainly keep an eye on line voltage. Also not hooked up yet.
I think a dip in voltage would cause a glitch in the data stream to/from the hard drive. It fails in different ways different times. Sometimes the cursor is frozen, sometimes the screen is in sleep mode and never wakes up. Once in a while it's in an rxvt window so I can actually try commands. The hard drive partition is unmounted at that point apparently.
ab1jx
Sat Nov 25, 2017 5:56 pm
OK, here's the DrOK watching the hard drive, about half an amp. I've seen it up around 0.6 depending what's going on. The voltage is a nice 4.99 volts most of the time. I assume that's probably the output regulator in the power supply holding it at that. Except if the line voltage does a nosedive and it can't. But that may only be for a few milliseconds, I don't have anything set up that can monitor that. A big fat capacitor to smooth the output might help.
I stuck in one of the 5v regulators to show it. The USB plug at top is to the powered hub, there's nothing else plugged in.
The drive power usage seems high, the LED is almost always on. That's always been the case.
sora03
Sun Nov 26, 2017 1:29 am
are you using a Y-USB (1 USB port for data+power and another for power only) cable to power the HDD? my second problem after fixing the power problem is the Y-cable, I need replug it again and again until the HDD works fine. you are now using the regulator right? adding a capacitor to smooth out the output is also a solution for me and it also eliminated the clicking noise (maybe from the HDD or the WiFi?) in the 3.5mm audio output
ab1jx
Sun Nov 26, 2017 2:19 am
No, I have no Y cables. There's 1 cable that comes out of this Startech adapter for both signal and power, that's plugged directly into the Pi. https://www.amazon.com/gp/product/B00R4 ... UTF8&psc=1 The regulator isn't connected at all, it's just sitting there.
It worked fine from about June until a week ago, I've tried replugging cables. I think it's the weather, we have about no significant wind in the summer, we've already had a few periods of 50 MPH gusts in the last weeks. When the tree crews don't do a good enough job of trimming branches we get a lot of power outages, and sometimes episodes of the lights flickering and some things rebooting. I think it's something like that. I just never saw anything else act quite this way. It doesn't reboot, it just has random problems, but most seem to come from the hard drive USB connection. I'd love to stick about 50,000 MFD across the USB bus power leads.
I eventually plugged my RTL2832 dongle back into the powered hub so maybe I can get back to the program I'm working on, no surprises.
ab1jx
Sun Dec 10, 2017 4:03 pm
Well, it wasn't the wind. It still happens.
What I find interesting is that I'm trying to copy 35 CDs I burned in 2002 onto the hard drive and sometimes among other problems the LED on the cdrom drive goes out in the middle of copying a file. A couple times I've tried to remount the CD and gotten "no media found". Powering everything down and back up gets it working again. This is a Liteon USB CD/DVD drive about a month old that I just used for the first time yesterday.
Thinking back on it, when I burned the CDs I had a terrible old HP CD burner, and what I see now fairly consistently is that about the first 2/3 of each disk is fine, beyond that I have problems (sometimes). The HP drive had trouble accessing certain tracks.
But it's another instance of mounting a filesystem over USB, both the hard drive and cdrom are connected over USB.
Probably not related, I'm trying to get an old Canon A520 camera to work over USB. I just bought one of the official Canon miniusb cables in case there was something odd and proprietary about it. It doesn't show up in dmesg or lsusb at all, gphoto (and gtkam) don't see it but they work fine with my Nikons. It's from 2005 so it's more like USB 1.0 maybe.
