fkbreitl
w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
Wed Nov 01, 2017 11:49 pm
After installing the new Raspbian strecht (2017-08-16-raspbian-stretch.img) I started seeing these messages in /var/log/syslog:
Aug 23 10:11:53 raspberrypi kernel: [  260.016295] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
Aug 23 10:12:57 raspberrypi kernel: [  323.617807] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered.
Aug 23 10:13:35 raspberrypi kernel: [  361.538322] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered.
Aug 23 10:14:15 raspberrypi kernel: [  402.019039] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered.
Also a recent apt upgrade didn't change the situation. My current kernel is
Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
What do these messages mean?
Re: w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
Thu Nov 02, 2017 6:00 am
Do you have any 1-wire devices connected to your Pi (DS18B20 temperature sensor for example)?
If so, they are not connected correctly as the Pi is not detecting any. Those messages appear when no sensors are connected.
If you don't have any sensors connected you can ignore those messages, or disable the w1 (1-wire) driver in raspi-config or the Pi configuration program to get rid of them.
fkbreitl
Thu Nov 02, 2017 11:32 am
No, I don't have any of those devices.
But seems like this driver is enabled by default and looking for devices.
Is this really a good idea or just adding another source of failure?
At least it shouldn't report errors if no devices are found, which is the most common situation, and its origin should be more clear.
How can I disable this driver then or at least its alarming error messages?
pcmanbob
Thu Nov 02, 2017 11:43 am
use
 sudo  raspi-config
option 5 interfacing option p7 1-wire in answer to question do you want it enable select NO
fkbreitl
Thu Nov 02, 2017 11:49 am
Thanks, I found the entry in raspi-config (Interfacing Options=>1-Wire), but I would also like to know what changes raspi-config is actually doing so that I can use it in my raspbian config script.
Looking at /usr/bin/raspi-config it seems to be commenting in or out
dtoverlay=w1-gpio
in /boot/config.txt
Is this all?
pcmanbob
Thu Nov 02, 2017 12:46 pm
Yes as far as I know that's all it does.
fkbreitl
Thu Nov 02, 2017 1:15 pm
Great, the error went away after commenting out the above line.
This configuration should be the default!
pcmanbob
Thu Nov 02, 2017 1:30 pm
As I remember it was the default to have all interfaces off in raspbian Jessie, guess its another change that was made in stretch but as to why I have no idea. :?
fkbreitl
Thu Nov 02, 2017 1:43 pm
I have requested this to be changed here:
viewtopic.php?f=66&t=196727
I hope it is the right place.
bensimmo
Thu Nov 02, 2017 1:46 pm
dtoverlay=w1-gpio
in /boot/config.txt
Is this all?
Here is what it does, all the code
https://github.com/RPi-Distro/raspi-config
fkbreitl
Thu Nov 02, 2017 9:52 pm
Thank you.
And as it turns out, it is not in the default config.txt of the fresh Raspbian images.
In my case it must have gotten there somehow by accident ...
