deady1000
VPN not working
Mon Oct 30, 2017 4:40 pm
Hello guys,
I can't use my vpn on my RaspberryPi3.
Latest fresh (!) raspbian, updates, upgrades and rpi-updates are installed.
RPI is connected over ethernet.
Webbrowser chromium is working good and is also connected to the internet.
So I installed openvpn and network-manager-openvpn.
My vpn-host is "private internet access".
I could use it with the console by typing "sudo openvpn Netherlands.ovpn" for example.
I tried several tutorials to install it but when I start the vpn the RPi loses the internet-connection (LAN still working) until I disconnect it again.
Is there any working GUI which I could use instead?
I tried GADMIN-openvpn-client but it won't launch when I start it.
Thank you for your help.
Greetings!
Snuggere
Re: VPN not working
Mon Nov 20, 2017 3:11 pm
I also have an issue with my VPN.
I get an error message that a key is not initialised and that it is dropping packets.
I am almost sure it is the following issue: https://community.openvpn.net/openvpn/ticket/903
This is a know bug with the current package 2.4.0 that comes with stretch. the issue would be solved if I could upgrade to 2.4.3.
But that i don't know how to do, or to downgrade the openvpn to 2.3.
Any help i sappreciated.
