I tried using this showing:
pi@raspberrypi:~ $ sudo apt-get install install-info
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
install-info
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B/307 kB of archives.
After this operation, 351 kB of additional disk space will be used.
Selecting previously unselected package install-info.
(Reading database ... 130696 files and directories currently installed.)
Preparing to unpack .../install-info_6.3.0.dfsg.1-1+b1_armhf.deb ...
Unpacking install-info (6.3.0.dfsg.1-1+b1) ...
Setting up install-info (6.3.0.dfsg.1-1+b1) ...
/usr/sbin/update-info-dir: 3: /etc/default/locale: �: not found
dpkg: error processing package install-info (--configure):
subprocess installed post-installation script returned error exit status 127
install-info
