apt-get segmentation fault
Posted: Sun Oct 22, 2017 12:57 pm
by VascoFerraz
Can anyone please help with this:
[email protected]:~ $ sudo apt-get install --reinstall ntfs-3g
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 375 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian stretch/main armhf ntfs-3g armhf 1:2016.2.22AR.1+dfsg-1 [375 kB]
Fetched 375 kB in 20s (18.1 kB/s)
Segmentation fault
E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1)
E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
Re: apt-get segmentation fault
Posted: Sun Oct 22, 2017 5:18 pm
by gkaiseril
Some part of the upgrade process failed.
I would restart the computer and try again. This should clear any locked files.
If it still fails. then you may need to clear some of the file directories used by apt-get.
sudo rm -rf /var/cache/apt/*.bin
sudo rm -rf /usr/bin/apt-listchanges/*.*
And try again.
Posted: Mon Oct 23, 2017 8:47 am
by VascoFerraz
And try again.
Problem is still present :(
Posted: Mon Oct 23, 2017 1:28 pm
by VascoFerraz
I think the problem is in the apt-listchanges
But if I download it and install it with dpkg I get:
[email protected]:~ $ sudo dpkg -i apt-listchanges_3.14_all.deb
(Reading database ... 125795 files and directories currently installed.)
Preparing to unpack apt-listchanges_3.14_all.deb ...
Segmentation fault
dpkg: warning: subprocess old pre-removal script returned error exit status 139
dpkg: trying script from the new package instead ...
Segmentation fault
dpkg: error processing archive apt-listchanges_3.14_all.deb (--install):
 subprocess new pre-removal script returned error exit status 139
Segmentation fault
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 139
Posted: Mon Oct 23, 2017 2:53 pm
by asavah
Do you have any free space left on sdcard?
Check with
df -h
Posted: Mon Oct 23, 2017 3:11 pm
by VascoFerraz
Check with
df -h
[email protected]:~ $ sudo df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G  4.3G  9.7G  31% /
devtmpfs        370M     0  370M   0% /dev
tmpfs           375M     0  375M   0% /dev/shm
tmpfs           375M   11M  365M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           375M     0  375M   0% /sys/fs/cgroup
/dev/sda1        15G  1.1G   14G   7% /media/pen16gb
/dev/sdb1        60G   47G   14G  78% /media/pen64gb
/dev/mmcblk0p1   42M   21M   21M  51% /boot
tmpfs            75M     0   75M   0% /run/user/109
tmpfs            75M     0   75M   0% /run/user/1000
I downloaded some packages from the repository and I was able to install successfully using dpkg.
Except for: apt-listchanges_3.14_all.deb
Posted: Mon Oct 23, 2017 3:16 pm
by DougieLawson
Why are you trying to install an X86_64 package on an ARM based processor. If you want that function you will need to build it from source code.
Posted: Mon Oct 23, 2017 3:21 pm
by rpdom
I see no X86_64 package.
Posted: Mon Oct 23, 2017 3:28 pm
by VascoFerraz
As far as I know I am on the RPI repository.
Where did you see in my posts that I am installing a X86_64 package?
Posted: Mon Oct 23, 2017 3:29 pm
by DougieLawson
apt-listchanges_3.14_all.deb appears to be an Ubuntu X86_64 package. No armhf version available, as far as I can see.
Posted: Mon Oct 23, 2017 3:34 pm
by VascoFerraz
Is it normal to have a X86_64 package in the Raspbian repository?
http://mirrordirector.raspbian.org/rasp ... stchanges/
Posted: Mon Oct 23, 2017 4:41 pm
by DougieLawson
It's just that a segfault is normally (as in 99.9999% of the time) due to trying to run X86/X86_64 code on a Raspberry.
Posted: Mon Oct 23, 2017 6:15 pm
by gkaiseril
I had no problem installing it in stretch on a 32 GB card on a Pi 3.
Posted: Mon Oct 23, 2017 6:23 pm
by rpdom
The "_all" in the name is an indication that it is for ALL architectures. There should be no arch specific code in it.
Posted: Tue Oct 24, 2017 8:41 am
by VascoFerraz
I have no idea what is going on. I think I have to reflash the Pi.
I never did a rpi-update, just apt-get update, upgrade and dist-upgrade
That's strange because my Pi1 never had this kind of issues.
Pi3 suddenly breaks regularly out of nothing (this is not the first time).
Posted: Tue Oct 24, 2017 2:51 pm
by VascoFerraz
After messing around with some packages I found that python3.5 also had problems.
I manually installed all python3.5 dependencies.
Then, I manually installed python3.5 and finally apt-listchanges.
Problem solved.
Posted: Mon Aug 20, 2018 9:55 am
by chrstphrchvz
Problem solved.
This makes sense. If there is a segmentation fault running `python3`, then the same would happen for running `apt-listchanges` since it is just a Python 3 script.
I'm using packages from debian testing, and encountered an issue very similar to this with Python 3.6.5-rc1, where even trying to reinstall/upgrade apt-listchanges didn't seem possible due to errors running apt-listchanges. Manually upgrading everything currently installed from the python36 and python3-stdlib-extensions source packages to 3.6.6 seemed to solve the problem for me.
