No Sound Output
Posted: Sat Oct 21, 2017 9:35 pm
by marekpi
My Pi doesn't seem to output any sound. I tried connecting headphones and nothing...
Any ideas?
Re: No Sound Output
Posted: Sat Oct 21, 2017 9:38 pm
by DirkS
Re: No Sound Output
Posted: Sat Oct 21, 2017 10:05 pm
by marekpi
Thanks for the link. I had a look at the page but it's all about coding.
Is there no visual way of doing it?
Re: No Sound Output
Posted: Sat Oct 21, 2017 10:56 pm
by DirkS
marekpi wrote: ↑Sat Oct 21, 2017 10:05 pm
No idea. My only desktop Pi doesn't have sound output...
Why not just try it from the CLI. It's not rocket science!
Re: No Sound Output
Posted: Sat Oct 21, 2017 11:21 pm
by mahjongg
no!
its not coding, its making some choices from a menu, and in some cases a bit command line use.
A raspberry pi is not about hand holding, its about learning to use a computer in its unadulterated form, if you cannot cope with that a PI is not for you!
Re: No Sound Output
Posted: Sat Oct 21, 2017 11:45 pm
by klricks
Right click on the speaker icon in the task bar and choose Analog.
Left click to set volume.
Note that the Audio on AV jack is intended to be connected to amplified speakers or to red and white RCA type audio inputs on a TV or other audio equipment.
Headphones should still work but not optimal.
Re: No Sound Output
Posted: Wed Nov 08, 2017 11:10 pm
by marekpi
Right-clicking on Sound and changing to Analog doesn't help. Still no sound using headphone jack...
Re: No Sound Output
Posted: Thu Nov 09, 2017 6:50 am
by fruitoftheloom
marekpi wrote: ↑Wed Nov 08, 2017 11:10 pm
Test with mains power speakers, headphones have no amplification.
Re: No Sound Output
Posted: Thu Nov 09, 2017 8:14 am
by Imperf3kt
fruitoftheloom wrote: ↑Thu Nov 09, 2017 6:50 am
Depending on your configuration, it is not always necessary to need amplification.
In my case, one pair of headphones is almost inaudible, however when I connect up a 5.25" 4Ohm speaker salvaged from an old hifi system from the 90's,I get perfectly acceptible volume.
Could be better (thats where my PAM8403 comes in) but it is otherwise easily heard from several feet away.
I'd suggest trying a different pair of headphones first, if you need to buy powered speakers.
Re: No Sound Output
Posted: Fri Nov 10, 2017 10:07 am
by marekpi
I tried connecting a mains-powered speaker and... nothing. No sound...
Re: No Sound Output
Posted: Wed Nov 15, 2017 10:06 am
by marekpi
Can anyone help?
