issue mounting usb drive
Posted: Tue Oct 03, 2017 12:28 pm
by geneworld
Hey Guys,
I'm running into an issue which it rattling my brain.
I have one of my Pi ZeroW running the 08-16-17 raspbian stretch image.
my
/etc/fstab
looks like
proc            /proc           proc    defaults          0       0
PARTUUID=4a6c32b1-01  /boot           vfat    defaults          0       2
PARTUUID=4a6c32b1-02  /               ext4    defaults,noatime  0       1
UUID=ECAADEE5AADEAAFA /home/pi/media/usb ntfs auto,nofail,noatime,users,rw,uid=pi,gid=pi 0 0            #Red Scandisk 64Gb
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
I have ntfs-3g installed also.
When I run
sudo mount -a
and then
df -h
i get :
pi@cloud:~ $ sudo mount -a
pi@cloud:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        30G  4.9G   24G  18% /
devtmpfs        213M     0  213M   0% /dev
tmpfs           218M     0  218M   0% /dev/shm
tmpfs           218M  6.2M  211M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           218M     0  218M   0% /sys/fs/cgroup
/dev/mmcblk0p1   42M   21M   21M  51% /boot
tmpfs            44M     0   44M   0% /run/user/1000
pi@cloud:~ $
My usb drive doesn't mount, however if i run
sudo mount -a; df -h /code] I get
 [code]pi@cloud:~ $ sudo mount -a; df -h
/dev/sda1        59G   28G   32G  47% /home/pi/media/usb
pi@cloud:~ $
Looks good! However it seems like it unmounts right away?? because if I then check again with
df -h
I get
pi@cloud:~ $ df -h
pi@cloud:~ $
I'm stumped! I've had no issue with this in the past but for some reason it now doesn't work.
Does anyone have any suggestions??
Re: issue mounting usb drive
Posted: Tue Oct 03, 2017 4:50 pm
by DirkS
Does the mount show up with
mount
Posted: Tue Oct 03, 2017 6:57 pm
by geneworld
mount
Here is what I get when I type
mount
pi@cloud:~ $ mount
/dev/mmcblk0p2 on / type ext4 (rw,noatime,data=ordered)
devtmpfs on /dev type devtmpfs (rw,relatime,size=217964k,nr_inodes=54491,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=44452k,mode=700,uid=1000,gid=1000)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
pi@cloud:~ $
Posted: Tue Oct 03, 2017 7:08 pm
by geneworld
After some reading I've added
max_usb_current=1
in
/boot/config.txt
and it seemed to do the trick when I reboot the Pi.
However, If i then unmount it and try to mount it again i run into the same issues. :?:
Posted: Tue Oct 03, 2017 7:18 pm
by DirkS
Have you checked the log with 'dmesg'?
What type of drive is it (3.5" / 2.5" HDD, memory stick, ...)?
Is it powered by the Pi?
