guerlando
Rpi Zero W interface not found when edit wpa_supplicant.conf
Sat Sep 30, 2017 1:39 am
When I burn the image on the SD and do nothing, I can see the wifi list in the raspbian desktop widget. When I burn the image and edit just the file wpa_supplicant erasing its content and adding:
network={
ssid="MySSID"
psk=my_psk
then I get "no interfaces found" when I click on the widget. What is the problem? I did exactly as mentioned in https://www.raspberrypi.org/documentati ... ess-cli.md
klricks
Re: Rpi Zero W interface not found when edit wpa_supplicant.conf
Sat Sep 30, 2017 2:59 am
network={
ssid="MySSID"
psk=my_psk
I think the newer release Rapbian Streatch requires more information.
update_config=1
country=US
network={
        ssid="Your SSID"
        psk="Your PSK"
        key_mgmt=WPA-PSK
Change the country code to match or set country using GUI config tool.
