To connect raspberry pi 3 with RS232 module
Posted: Wed Sep 27, 2017 9:58 am
by connectororconductor
Hi, I have a RS232 to TTL Serial Interface Module, I would like to know the steps to connect it to raspberry pi 3. Are there any instructables or series of steps to connect these two.
Re: To connect raspberry pi 3 with RS232 module
Posted: Wed Sep 27, 2017 12:32 pm
by drgeoff
If it is genuinely a "TTL" one then it uses 5 volt logic levels and should not be connected to a RPi as the GPIOs on RPis use 3.3 volt logic levels. RPi GPIO inputs are not 5 volt tolerant and fatality of the complete RPi can result.
Some modules do use 3.3 volt levels.
Posted: Wed Sep 27, 2017 12:48 pm
by klricks
connectororconductor wrote: ↑Wed Sep 27, 2017 9:58 am
Make sure the chip on the module is MAX3232 and not MAX232. If MAX232 then you will need to add a level shifter circuit between.
Give a link to your module specifications.
