NeoPixel stick works with rPi 3, but not with Pi Zero?!?
Posted: Sun Sep 17, 2017 11:08 am
I created a test setup on my Raspberry Pi 3 and got the Neopixel Stick (8 x 5050 RGBW) work like it should.
I use the following library https://github.com/jgarff/rpi_ws281x.git
Now I compile this same library on a Pi Zero (v1.3) and connect the Neopixel stick to it.
Using the same code, the Neopixel stick does not respond to the code. When I CTRL+C my python program, the LEDs turn all on full brightness white.
Also the test script and test Python programs supplied with the rpi_ws281x library react the same.
I tried different Pi Zero's, alway use GPIO18.
What could go wrong?
