Kernel Panic: VFS : Unable to mount root fs on unknown-block
Posted: Sat Oct 06, 2012 1:49 am
Hi guys,
I've been tearing my hair out at my new Pi for the last 2 days trying to get an OS to boot on the damn thing, I've done some trawling on the forum and so far have not turned up anything that has helped me to fix this issue.
I am using a stock-clocked Pi, standard RS power supply, Sandisk 16GB Class 4 SD card (which is painfully slow, I just spent something like 3 hours waiting for the thing to format), generic USB keyboard and wireless Microsoft Arc Mouse.
I have formatted the SD card several times now with the SD formatter utility and have tried to install both BerryBoot and the newest version of Raspbian (with Win32DiskImager) with similar results, both complain of issues relating to not being able to mount the filesystem on the SD before it even gets chance to install. The message that appears right before kdb is started when I attempt to install Raspbian is "Kernel Panic: VFS : Unable to mount root fs on unknown-block". I have tried starting the Pi both with and without the USB devices plugged in, unfortunately it makes no difference; given that the card appears to work perfectly fine within Windows I am fairly sure the card isn't the issue either.
Is anyone familiar with this issue? I'm very much new to linux (every time I attempt to extend the olive branch I have hit frustrating issues like this one and decided it isn't worth the hassle despite wanting to learn) but am fairly technically-minded, although given the Pi is completely unresponsive when this issue occurs so there isn't a whole lot I feel I can do to trace the issue.
I'm happy to try pretty much any longshot at the moment, let me know if you would like any specific information to help isolate the issue (I know there is not too much in here, unfortunately I am at my partner's house and don't have the Pi with me to pull any specifics up).
