SQLite3 issues
Posted: Mon Sep 04, 2017 12:19 am
I'm trying to set up a SQLite database for DHT22 sensor readings. I seem to be able to create the DB and set up the DB table OK.
The issue is that when I attempt to insert values into the table I get a Error: no such column: 'foo'. I also tried
a alternate method and the same thing happened. Then it refused to let me quit or get help. Finally had to crash out of SQLite.
Had to reboot and then it did the same. Tried reinstalling SQLite3 and no help. I would like to make this work but I'm out of options.
Any thoughts?
Raspi 2b
Raspbain Jessie, Updated Upgraded
Adafruit_Python_DHT.git setup and tested
I2S setup and tested
SQLite3
Any thoughts?
Raspi 2b
SQLite3
