iurly
USB device SOMETIMES not recognized at boot
Thu Aug 31, 2017 1:29 pm
I'm seeing some weird issues with a CP210x connected to a port of the Raspberry PI 3:
After a powercycle, it sometimes happens (about 1% of the times?) that the device is not enumerated.
I just don'see it in dmesg. The red power LED is on, but lsusb just doesn't see it:
pi@rpi3-10:/sys $ lsusb -tv
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
        |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
        |__ Port 4: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 480M
Even if I try resetting the hub, I can't get much further:
root@rpi3-10:/sys/bus/usb/drivers# echo 1-1:1.0 > hub/unbind
pi@rpi3-10:/sys/bus/usb/drivers $ lsusb -t
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=/0p, 480M
root@rpi3-10:/sys/bus/usb/drivers/hub# echo 1-1:1.0 > bind
pi@rpi3-10:/sys/bus/usb/drivers/hub $ lsusb
Bus 001 Device 006: ID 18a5:0245 Verbatim, Ltd
Bus 001 Device 005: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
So the other two devices get correctly detected but my CP210x doesn't.
After a software reboot, everything works just fine:
        |__ Port 2: Dev 4, If 0, Class=Vendor Specific Class, Driver=cp210x, 12M
        |__ Port 4: Dev 5, If 0, Class=Mass Storage, Driver=usb-storage, 480M
I haven't tried unplugging/replugging the device the last time around; I vaguely recall it worked the last time I tried it but I can't be 100% sure.
Notice how I have the following settings and kernel version:
pi@rpi3-10:~ $ uname -a
Linux rpi3-10 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux
pi@rpi3-10:~ $ cat /proc/cmdline
8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x64aed3f3 smsc95xx.macaddr=B8:27:EB:AE:D3:F3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait dwc_otg.nak_holdoff=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x7
The esoteric dwc_otg settings were necessary to fix some reliability issues when streaming data at 2.000.000 bps over the UART (the CP210x is a full-speed device).
See https://www.raspberrypi.org/documentati ... /README.md and https://bitcointalk.org/index.php?topic=843788.0
I haven't tested any other Full-Speed device but I might assume they may fall into the same category.
Any ideas?
Re: USB device SOMETIMES not recognized at boot
Thu Aug 31, 2017 4:57 pm
Grab a factory fresh SDCard, build a copy of Raspbian Stretch (or NOOBS 2.4.3) on it. Boot that and see what happens. Your current system is a bit ancient and there's a strong possiblity that new things in Stretch have fixed your failure.
Canedje
Fri Sep 01, 2017 6:52 am
I'm not sure about the solution I tell now, but in the past I had the same problem.
In my case at the end it proved that the connector of the USB cable was not 100% right.
I did resolder the connector the USB connector from the cable. After that I had no problems anymore.
