Problem with SPI after updating to Stretch - RESOLVED
Posted: Wed Aug 23, 2017 8:31 pm
by dirdled
Hi, I've updated my trusty Raspberry pi 2 to stretch, and now I can't get one of my staple scripts to work. It's a python script that accesses an mcp3008 to monitor light and temperatures. the SPI interface says it's on, and the script runs without any errors, but the calls to the mcp3008 are all returning 0. If I put the SD card with jessie on it back in everything works, so It's not a programming or wiring error. I'm pretty sure it just something I missed and forgot to re-install after the update, but without an error I don't know where to look. Anyone have any ideas where I could start?
Re: Problem with SPI after updating to Stretch
Posted: Wed Aug 23, 2017 11:57 pm
by bulletmark
What kernel version and what SPI library are you using with your python app?
Posted: Thu Aug 24, 2017 12:47 am
by dirdled
I hope this answers what you're asking
The kernel version is Kernel version: Linux 4.9.43-v7+ armv7l
and the SPI Lib Im using is
I'm not sure how to find a version of spidev
Posted: Thu Aug 24, 2017 12:53 am
by bulletmark
I use Arch Linux, not Raspbian but I bet your problem is the same as I experienced due to the recent upgrade to kernel version 4.9.43.
I fixed my problem with https://github.com/bulletmark/pifaceio/ ... 785221ff21.
You don't say what SPI library you are using but it needs the same fix, or you need to change your app to explicity set the SPI transfer speed if the SPI library allows you.
Posted: Thu Aug 24, 2017 1:30 am
by dirdled
Very cool...All bow to the big brain on Bulletmark...That seems to have fixed it, I added one line
spi.max_speed_hz = 5000
Immediately following the spi.open command and it seems to be working now...I'll report back if I find out differently.
Just curious but how do I know what a good value would be? I played around and it was look like it worked with pretty much everything I threw at it I tried values from 50 to 1000000.
In case you can't tell I'm not a hardware person (yet)
Posted: Thu Aug 24, 2017 1:34 am
by bulletmark
I looked at the data sheet for the MCP23S17 chip I am using and see that it is spec'd for up to 10 MHz so used that.
Re: Problem with SPI after updating to Stretch - RESOLVED
Posted: Thu Aug 24, 2017 1:45 am
by dirdled
Hmm, I looked at your data sheet and it comes right out and says
High-SpeedSPIInterface(MCP23S17): - 10MHz(maximum)
for mine it's a little more cryptic for the MCP3008. If I'm looking at the right place it looks like it says the Clock Frequency is either 3.6 or 1.35 Mhz based on the Vdd
Is there a benefit to running it at a less than maximum speed? Like longer chip life, or lower energy consumption?
(When you get tired of answering stuff just tell me to go away, You already got it working for me so I'm grateful)
Posted: Thu Aug 24, 2017 1:56 am
by bulletmark
I'm not a hardware guy either sorry so can't comment. Google seems to give plenty of links about SPI speed and MCP3008 though.
