Error: Hardware does not support sending LIRC Raspberry PI 3
Posted: Tue Aug 22, 2017 1:17 pm
by fesooli
I'm trying to make a remote control for my Samgung TV with raspberry pi 3, and Raspbian (4.9) OS.
I was following this tutorial: https://www.hackster.io/austin-stanton/ ... irc-2fd581
But when i arrived in the 5 step, i got the error: Hardware does not support sending
I can receive commands from my remote, but i cant send for my tv.
There are some pictures of the LIRC configuration and my circuit:
File /etc/modules
lirc_dev
lirc_rpi gpio_in_pin=23 gpio_out_pin=22
File /boot/config.txt
dtoverlay=lirc-rpi,gpio_in_pin=23,gpio_out_pin=22
Command that i used to send the signal:
irsend -d /dev/lirc0 SEND_ONCE Samsung KEY_POWER
Can anyone help me, please?
Re: Error: Hardware does not support sending LIRC Raspberry PI 3
Posted: Tue Sep 19, 2017 7:37 am
by jme2401
i have the same problem with raspbian stretch. I think there is something wrong with rasbian stretch and lirc 0.9.4. IPerhaps someone has an idea what has changed with raspbian stretch or lirc 0.9.4.
Posted: Wed Sep 20, 2017 8:13 am
by jme2401
Turns out that this helps:
viewtopic.php?f=28&t=192891#p1212574
according to the instruction located at "/usr/share/doc/lirc/README.Debian.gz":
## 0.9.4 disruptive update
The configuration is so much changed that updating from 0.9.0 requires
manual intervention. This could be done using the update scripts or as
a completely manual process. Many users will always need some manual steps.
There is script to "convert" the configuration:
sudo /usr/share/lirc/lirc-old2new.sh
after that you can reboot your pi order simply restart LIRC
Posted: Fri May 04, 2018 3:12 am
by bertrodgerseh
thanks,
that fixed issue with pi zero w for me.
