ankur_r
Respberry PI2 B V1.1 Memory card holder, ESP8266,ESP32 Development board ? ?
Mon Aug 21, 2017 11:01 pm
Hi All,
Actually the memory card holder of my Raspberry Pi-2 board is not functioning well. After pushing the card into holder, it is not locking, it just pop up the card from holder other function are absolutely fine.
1. Is some USB Card reader at USB Port can be an alternative, I tried but it wasnt worked. Can any other alternative possible ??
2. Additionally Can anybody help to start with below provided hardware boards with Respberry Pi 2 B V1.1
http://www.amazon.in/Serial-ESP8266-Rem ... ge_o02_s00
http://www.amazon.in/ESP32-Wifi-Bluetoo ... ge_o04_s00
What additionally hardware, circuit, tool chain with noobs, ubuntu, rtos is needed ??
Thanks.
Ankur
wh7qq
Re: Respberry PI2 B V1.1 Memory card holder, ESP8266,ESP32 Development board ? ?
Tue Aug 22, 2017 12:27 am
My short term solution to this problem was an elastic band to hold the uSD card in place but the rubber will rot out and fail and the fit with some cases is a problem. For a long term fix, I fixed this extension card in place with hot-melt adhesive: https://www.amazon.com/gp/product/B071N ... UTF8&psc=1 The hot-melt is not conductive but you need to take some care to avoid contaminating any contacts with it. I applied it at the edge of the RPI board and at the metal edge of the original card holder. The extension card's holder is just a friction fit as found on the zero and the 3B...no spring.
Tue Aug 22, 2017 5:58 am
I have also used the elastic band method, although I eventually got some fine tipped tweezers and pulled out the spring from the SD card slot (just about visible through a hole in the top of the card slot) and now the card is push-in/pull-out just like the Pi 3
