TRyan
Raspbian stretch No OpenGL driver
Fri Aug 18, 2017 6:41 am
I make a fresh install with raspbian-stretch-lite and install the PIXEL Desktop.
Everything is working fine, but I am not able to activate the OpenGL driver.
I install: xcompmgr libgl1-mesa-dri
Memory Split =256
glxgears looks every time the same.
I make several reboots, but noting change.
Thanks for your help.
Greetings Tobias
cjan
Re: Raspbian stretch No OpenGL driver
Fri Aug 18, 2017 6:55 am
goto raspi-config to enable GL driver.
TRyan
Fri Aug 18, 2017 7:05 am
yes I did that and make a reboot. No change.
Tobias
TRyan
Fri Aug 18, 2017 7:54 am
with the image raspbian-stretch with PIXEL there are no problems to enable the OpenGL Driver.
Are there "special" packed that I need?
Greetings Tobias
rpiMike
Fri Aug 18, 2017 7:59 am
OpenGL is working fine for me on Stretch.
You don't need to install anything - just enable in raspi-config.
If you want glxgears (unless its already installed) use :
sudo apt-get -y install mesa-utils
TRyan
Fri Aug 18, 2017 8:12 am
Hi
The Problem is:
image raspbian-stretch with PIXEL -> no problem with the OpenGL
image raspbian-stretch light and additional installed PiXEL -> I can not enable OpenGL
Greetings Tobias
runboy93
Fri Aug 18, 2017 8:37 am
Atleast now it's using Mesa "13.0.6-1", latest (final release, better move next to closest final release 17.1 branch) 13.x series build.
Fri Aug 18, 2017 8:40 am
Hi
The Problem is:
Greetings Tobias
How did you get the Pixel Desktop ?
It was retired 2 months ago and the standard desktop is Raspberry Pi Desktop:
viewtopic.php?f=63&t=186959
TRyan
Fri Aug 18, 2017 8:49 am
thanks for your Help.
I write the raspbian-stretch light image on SDkarte
For the PIXEL GUI I installed:
sudo apt-get install --no-install-recommends xserver-xorg
sudo apt-get install --no-install-recommends xinit
sudo apt-get install raspberrypi-ui-mods
sudo apt-get install --no-install-recommends raspberrypi-ui-mods lxterminal gvfs
@runboy93
Sorry, but how can I install the 17.1 from Mesa?
Thanks for your Help.
Greetings Tobias
runboy93
Fri Aug 18, 2017 8:51 am
@runboy93
Greetings Tobias
No no, don't yet move to 17.1. Wait until it's released via Raspberry Pi apts.
Fri Aug 18, 2017 8:54 am
@runboy93
Greetings Tobias
THAT IS NOT PIXEL DESKTOP, PLEASE READ THE LINK I POSTED :lol:
TRyan
Fri Aug 18, 2017 9:04 am
Sorry I am a little bit confused. :?
Maybe is better to say what I need:
Raspbian Stretch Lite with a Desktop and OpenGL support.
The Image Raspbian Stretch with desktop has to many programs, that I don't need
Greetings
Tobias
Fri Aug 18, 2017 9:26 am
Greetings
Tobias
You keep mentioning PIXEL Desktop that is confusing as there is no PIXEL Desktop as it no longer exists ;)
TRyan
Fri Aug 18, 2017 10:35 am
hmm... okay.
then I will use the Raspbian Stretch with desktop image for the Raspbbery Pi and delete everything that I don't use.
Greetings Tobias
Fri Aug 18, 2017 10:50 am
hmm... okay.
Greetings Tobias
You seem not to be comprehending that you are calling the Desktop PIXEL when IT IS NOT PIXEL !
loopmasta
Sat Sep 02, 2017 3:30 pm
Hi Tobias,
I am having a similar problem. I am using 2017-08-16-raspbian-stretch.img and removed most of the desktop apps that I don't use.
Glxgears runs with 60FPS but I can not get webGl working in chromium. raspi-config does not seem to react to any GL-driver changes.
I added my glxinfo below.
glxinfo
name of display: :0.0
libGL error: MESA-LOADER: failed to retrieve device information
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Broadcom (0x14e4)
Device: VC4 V3D 2.1 (0xffffffff)
Version: 13.0.6
Accelerated: yes
Video memory: 875MB
Unified memory: yes
Preferred profile: compat (0x2)
Max core profile version: 0.0
Max compat profile version: 2.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 2.0
OpenGL vendor string: Broadcom
OpenGL renderer string: Gallium 0.4 on VC4 V3D 2.1
OpenGL version string: 2.1 Mesa 13.0.6
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_AMD_shader_trinary_minmax, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ARB_ES2_compatibility,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_copy_buffer, GL_ARB_debug_output, GL_ARB_depth_texture,
GL_ARB_draw_buffers, GL_ARB_draw_elements_base_vertex,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_separate_shader_objects,
GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow,
GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_transpose_matrix, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_env_combine3, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_provoking_vertex, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shader_integer_mix, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_swizzle, GL_EXT_vertex_array, GL_IBM_multimode_draw_arrays,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_KHR_context_flush_control, GL_KHR_debug,
GL_MESA_pack_invert, GL_MESA_window_pos, GL_NV_blend_square,
GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
GL_NV_texture_rectangle, GL_OES_EGL_image, GL_OES_read_format,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 13.0.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
GL_APPLE_texture_max_level, GL_EXT_blend_minmax,
GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,
GL_EXT_draw_elements_base_vertex, GL_EXT_map_buffer_range,
GL_EXT_multi_draw_arrays, GL_EXT_read_format_bgra,
GL_EXT_separate_shader_objects, GL_EXT_texture_border_clamp,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_KHR_debug,
GL_NV_draw_buffers, GL_NV_fbo_color_attachments, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_OES_EGL_image, GL_OES_EGL_image_external, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
GL_OES_fbo_render_mipmap, GL_OES_get_program_binary, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_rgb8_rgba8, GL_OES_stencil8,
GL_OES_surfaceless_context, GL_OES_texture_3D,
GL_OES_texture_border_clamp, GL_OES_texture_npot,
GL_OES_vertex_array_object
runboy93
Sat Sep 02, 2017 5:23 pm
Have you updated / upgraded, and then activated VC4?
loopmasta
Sun Sep 03, 2017 12:58 pm
Yes I have updated / upgraded and set the GL drivers in the raspi-config / Advanced Options / GL Driver / to GL (Full KMS).
But webGL in chromium seems to be broken
runboy93
Sun Sep 03, 2017 2:21 pm
And you are sure it worked on Jessie build?
Then it could be buggy Chromium (V60 #89, introduced lot of regressions that were mostly fixed on #113), or GL drivers bug on Raspbian Lite. Have you reported this bug on github websites or just here and wait something happen?
https://raspberrypi.stackexchange.com/q ... -on-jessie (for Jessie, but could work on Stretch, if that "--disable-gpu" switch is activated in there and you are trying to use GL drivers)
And I see you are using Lite version of Raspbian (Desktop installed later), and you said that it works with standard Desktop version, why not use it?
Maybe you could include "Lite" to topic header?
And also add screenshot from Chromium page "chrome:gpu", what does it say there?
Wayne Keenan
Sun Oct 29, 2017 3:54 pm
I had the same problem on Stretch (full fat, not Lite) and the chromium on Jessie was working.
After playing with a number of settings in chrome://flags and command line values I found the key to get it to work on Stretch was to:
1. use raspi-config to enable OpenGL (Full KMS)
2. remove "--disable-gpu-compositing'' from /etc/chromium-browser/customizations/00-rpi-var
After that I reset all chrome://flags values to default (the button in the top right of that page) and when launching chromium from the desktop icon (i.e. no user flags) I can see the spinning cube at: https://get.webgl.org
For ref: rpi-update firmware hash is: a6b3e852ca70f2a12850b4542438583cc3b29788
A snippet of output of my [url]chrome://gpu/[/url] is below. The resetting of flags (or something else) changed Video encode/decode from Hardware accelerated to software, so maybe it's possible to get that back to HW Accel.
For my app I also upped the GPU mem split on my Pi3 to 512Mb, ymmv.
Graphics Feature Status
Canvas: Hardware accelerated
CheckerImaging: Disabled
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Software only. Hardware acceleration disabled
Rasterization: Software only. Hardware acceleration disabled
Video Decode: Software only, hardware acceleration unavailable
Video Encode: Software only, hardware acceleration unavailable
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Driver Bug Workarounds
clear_uniforms_before_first_program_use
count_all_in_varyings_packing
decode_encode_srgb_for_generatemipmap
disable_framebuffer_cmaa
disable_post_sub_buffers_for_onscreen_surfaces
scalarize_vec_and_mat_constructor_args
Wayne Keenan
Sun Oct 29, 2017 5:25 pm
I just retested and wanted to share that on a stock 2017-09-07 Stretch ( without 'rpi-update' or 'apt-get update' being run) on a Pi3, then the performing the following steps:
is all you need to do to get the https://get.webgl.org cube spinning.
antiriad
Contact: Twitter
Tue Aug 21, 2018 10:42 pm
aside from the fact that PIXEL Desktop is now Raspbian Desktop, it would be useful to know how to activate OpenGL acceleration on Raspbian Stretch LITE with manually-installed UI.
