BarrowWight
Raspberry PI B+ WiFi no longer working after upgrade to raspbian stretch.
Thu Aug 17, 2017 10:28 pm
I just upgraded my Raspberry Pi B+ to Stretch, to keep on top of security updates, but now my WiFi is not working. I have wpa_supplicant properly configured, and I know the WiFi adapter works, because running
sudo iw dev wlan0 scan | grep SSID
lists available networks. But it will not connect to my wifi.
BarrowWight
Re: Raspberry PI B+ WiFi no longer working after upgrade to raspbian stretch.
Fri Aug 18, 2017 1:06 am
I found a solution, do this:
ncguk wrote:
Thu Aug 17, 2017 11:02 pm
I've been fighting this all evening. My solution on a fresh Raspbian Lite install:
Make sure your wpa_supplicant.conf is in place then do
sudo nano /etc/network/interfaces
and add
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
to the end of the file. Then do
sudo systemctl enable wpa_supplicant.service
Then reboot.
Source: viewtopic.php?f=28&t=191061/#p1199674
ncguk
Fri Aug 18, 2017 9:59 am
Just to update this – I retested on a new Raspbian Lite Stretch install and the 'sudo systemctl enable wpa_supplicant.service' step is not necessary. Do everything else and reboot and it should work.
