Re: Really bad composite video out on Pi 3?
Posted: Mon Aug 14, 2017 5:48 pm
1. The TV in question is an NTSC one. I've since had a look in the user manual and didn't find an option to disable the comb filter.
2. Comb filtering is much easier with NTSC because of the simpler relationship between the line and subcarrier frequencies.
3. I still have one of those 13 inch Sony Trinitron TVs which avoided the PAL patent. The method employed was to use a 1H delay line (similar to that in a conventional PAL-D decoder) to substitute the chroma for every alternate (in time) line with that from the previous line. This converted the PAL chroma signal to one similar to NTSC but with the burst phase shifted by 45 degrees. An NTSC type decoder, tweaked for the different subcarrier frequency and the 45 degrees, recovered the two colour difference signals. Just like with a NTSC decoder, the set has a front panel hue control to fine tune the recovered subcarrier phase.
