adjusting gpu memory
Posted: Sat Aug 05, 2017 4:53 pm
by trogne
How can I adjust the gpu memory to 128 ?
I say that because in this article : https://www.linkedin.com/pulse/how-get- ... -kovalenko
It is asking to make sure we have 128 gpu memory.
But how can I adjust that ?
Thanks,
Patrick
Re: adjusting gpu memory
Posted: Sat Aug 05, 2017 4:56 pm
by davidcoton
Posted: Sat Aug 05, 2017 5:18 pm
by klricks
You can adjust memory by using the GUI config tool.
[Menu] --> [Preferences] --> [Raspberry pi config..] --> [Performance]
-OR-
From the advanced menu in:
sudo raspi-config
-OR-
By direct edit of /boot/config.txt
sudo nano /boot/config.txt
If a gpu_mem command exists then change it to 128 if not there then add the line at the end:
gpu_mem=128
Posted: Sat Aug 05, 2017 6:19 pm
by trogne
Great, thanks!!
