DaRk_St0rM
USB HDD crashing with Transmission
Fri Aug 04, 2017 5:59 pm
This thing really has me puzzled.I upgraded my Pi 2 to a 3 because of random problems when using Transmission with Raspbian and USB disks, after having being using a couple of them with the same 2.5" enclosure (originally from a Toshiba external drive), I was having trouble with an external-powered 3.5" and a Seagate 2.5" 4 TB one I bought recently.I was thinking of buying a Pi 3 soon anyway so I just went ahead.
I'm using a 2.4A charger which I bought recently and pretty much hadn't been used until I started using it for the Pi, and as far as I know it works fine.The disks work perfectly in both my laptop and desktop with Windows 10 and several GNU/Linux distros.I use an USB Wi-Fi adapter on the Pi.
I originally had problems in the Pi 2 with the 3.5" one, formatted in exFAT, both with FUSE and the native driver, and I bought the 2.5" one after buying the Pi 3, had problems with them both (that one has an exFAT partition and an ext4 one).After setting
max_usb_current
to 1 I did some tests and it seemed the problems were gone, and in fact I've been using the 3.5" one until today when it became full, so I switched to the other one.
I was inclined to think that the USB bus was having some power problems or something, but today I was able to write ~40 GB that I wanted to transfer to the new drive from the old one from Windows using Samba via Ethernet, at 11 MB/s, and the Ethernet adapter is connected to the USB hub after all.However, right after that I fired up Transmission and left something downloading.With my connection the maximum speed I can reach is about 7 MB/s but in this case it was downloading at 400 KB/s at most, and a couple of hours later I find the filesystem remounted R/O and dmesg flooded with stuff like:
[18798.601181] usb 1-1.4: reset high-speed USB device number 5 using dwc_otg
[18798.671397] INFO: task jbd2/sda2-8:490 blocked for more than 120 seconds.
[18798.671573]       Tainted: G           O    4.9.40-1-ARCH #1
[18798.671697] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[18798.671868] jbd2/sda2-8     D    0   490      2 0x00000000
[18798.672028] [<809bbc78>] (__schedule) from [<809bc2d0>] (schedule+0x3c/0xa0)
[18798.672194] [<809bc2d0>] (schedule) from [<809bf4ac>] (schedule_timeout+0x230/0x38c)
[18798.672375] [<809bf4ac>] (schedule_timeout) from [<809bb9a8>] (io_schedule_timeout+0xb0/0x130)
[18798.672570] [<809bb9a8>] (io_schedule_timeout) from [<809bcbb8>] (bit_wait_io+0x10/0x58)
[18798.681533] [<809bcbb8>] (bit_wait_io) from [<809bc794>] (__wait_on_bit+0x60/0xb8)
[18798.690758] [<809bc794>] (__wait_on_bit) from [<809bc910>] (out_of_line_wait_on_bit+0x78/0x9c)
[18798.700108] [<809bc910>] (out_of_line_wait_on_bit) from [<803902b0>] (jbd2_journal_commit_transaction+0xfb0/0x1824)
[18798.709398] [<803902b0>] (jbd2_journal_commit_transaction) from [<80395cbc>] (kjournald2+0xc8/0x2cc)
[18798.718627] [<80395cbc>] (kjournald2) from [<80149690>] (kthread+0x104/0x118)
[18798.723226] [<80149690>] (kthread) from [<80107b28>] (ret_from_fork+0x14/0x2c)
[18798.727663] INFO: task transmission-da:1395 blocked for more than 120 seconds.
I really can't understand it, as I said I've used two 2.5" disks in the past, both ext4 formatted, and filled them both downloading with Transmission, this is getting quite frustrating as it's the main thing I use my Pi for.
Re: USB HDD crashing with Transmission
Fri Aug 04, 2017 6:03 pm
Have you done any tests to see whether there's a hardware failure on that HDD?
Do you have an adequate (3.5A) power supply to run your RPi and your HDD?
DaRk_St0rM
Fri Aug 04, 2017 6:16 pm
Yes, the HDD is definitely fine.
I thought 2.5 was recommended for the Pi 3? I'm using a 2.4A power supply.
Fri Aug 04, 2017 6:22 pm
My three RPis with WD PiDrives all run with the WD 3.5A power supply. They still get a lightning bolt during boot up just as the HDD spins up.
julyjim
Sat Aug 05, 2017 1:12 am
Use lsusb -v and verify "max current" on your HDD . Use it as a guide.
ON RPi 3 B each USB port spec is 100 mA .
Unless things changed over years HDD spin all the time, but do not start same time , and USB
packages are passed on time shared basis - there should not be power issue there.
Sat Aug 05, 2017 9:15 am
ON RPi 3 B each USB port spec is 100 mA 500mA (max 1200mA across all four).
FTFY, you're welcome.
DaRk_St0rM
Sat Aug 05, 2017 12:08 pm
It says MaxPower is 500mA for both the HDD and the Wi-Fi adapter.
