Wifi drops out (with syslog error)
Posted: Sun Sep 30, 2012 5:03 pm
by fraser
I have a Ralink 5370 based USB Wifi adapter and i've tried it with and without a powered USB hub. Even with the powered hub it's dropping out semi-randomly (after a number of hours). I've tried switching off power saving, the output of iwconfig is below as well as syslog.
I setup a periodic 30 second ping to my local router to try and keepalive the underlying connection and it still goes down.
The syslog at the end shows things being lost then 'Link beat lost' followed by ifdown. It doesn't recover from this.
I've seen a few similar threads but nothing in them i've tried works.
Any ideas?
Thanks.
lo        no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:"WIFI"
          Mode:Managed  Frequency:2.467 GHz  Access Point: C0:D0:44:30:7A:38
          Bit Rate=36 Mb/s   Tx-Power=20 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=47/70  Signal level=-63 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:3   Missed beacon:0
eth0      no wireless extensions.
Sep 30 16:27:57 raspberrypi kernel: [99034.795440] ieee80211 phy0: wlan0: No probe response from AP c0:d0:44:30:7a:38 after 500ms, disconnecting.
Sep 30 16:27:57 raspberrypi kernel: [99034.826945] cfg80211: Calling CRDA to update world regulatory domain
Sep 30 16:27:57 raspberrypi ifplugd(wlan0)[951]: Link beat lost.
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: Executing '/etc/ifplugd/ifplugd.action wlan0 down'.
Sep 30 16:28:07 raspberrypi dhclient: Internet Systems Consortium DHCP Client 4.2.2
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: Internet Systems Consortium DHCP Client 4.2.2
Sep 30 16:28:07 raspberrypi dhclient: Copyright 2004-2011 Internet Systems Consortium.
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: Copyright 2004-2011 Internet Systems Consortium.
Sep 30 16:28:07 raspberrypi dhclient: All rights reserved.
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: All rights reserved.
Sep 30 16:28:07 raspberrypi dhclient: For info, please visit https://www.isc.org/software/dhcp/
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: For info, please visit https://www.isc.org/software/dhcp/
Sep 30 16:28:07 raspberrypi dhclient: Listening on LPF/wlan0/7c:dd:90:1c:e3:55
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: Listening on LPF/wlan0/7c:dd:90:1c:e3:55
Sep 30 16:28:07 raspberrypi dhclient: Sending on   LPF/wlan0/7c:dd:90:1c:e3:55
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: Sending on   LPF/wlan0/7c:dd:90:1c:e3:55
Sep 30 16:28:07 raspberrypi dhclient: Sending on   Socket/fallback
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: Sending on   Socket/fallback
Sep 30 16:28:07 raspberrypi dhclient: DHCPRELEASE on wlan0 to 192.168.0.1 port 67
Sep 30 16:28:07 raspberrypi ifplugd(wlan0)[951]: client: DHCPRELEASE on wlan0 to 192.168.0.1 port 67
Sep 30 16:28:08 raspberrypi ifplugd(wlan0)[951]: Program executed successfully.
Sep 30 16:28:09 raspberrypi ntpd[1471]: Deleting interface #2 wlan0, 192.168.0.9#123, interface stats: received=765, sent=707, dropped=0, active_time=99020 secs
Sep 30 16:28:09 raspberrypi ntpd[1471]: 195.228.75.149 interface 192.168.0.9 -> (none)
Sep 30 16:28:09 raspberrypi ntpd[1471]: 131.234.137.24 interface 192.168.0.9 -> (none)
Sep 30 16:28:09 raspberrypi ntpd[1471]: 213.239.154.12 interface 192.168.0.9 -> (none)
Sep 30 16:28:09 raspberrypi ntpd[1471]: 84.245.64.190 interface 192.168.0.9 -> (none)
Sep 30 16:28:09 raspberrypi ntpd[1471]: peers refreshed
Re: Wifi drops out (with syslog error)
Posted: Tue Jan 01, 2013 2:32 pm
by NewPi
did you found any solution ?
