eufc
Startx failing
Sat Sep 29, 2012 11:02 am
now it the desktop doesnt wont to boot up it doesnt even want to load the desktop now it goes through the code gives me a black screen and put me back where i put startx help asap
bredman
Re: SOS HELP
Sat Sep 29, 2012 1:32 pm
If you want help, you need to explain what you are doing and what is going wrong.
What do you mean by "it goes through the code"?
Has it ever worked or has it always failed?
Which username did you use to login?
Do you see any error messages?
Do you know which distribution you have downloaded?
Did you expand the size of your SD card?
Have you changed the memory split?
Please explain your problem calmly, using punctuation and paragraphs.
JeremyF
Re: SOS HELP
Sat Sep 29, 2012 2:24 pm
It sound like startx is failing for some reason. I predict that you are out of storage space. If you have a card bigger than 2GB, make sure the linux partition has been expanded in raspi-config.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
eufc
Re: SOS HELP
Sat Sep 29, 2012 7:43 pm
I haven't done anything with the sd card I just rebooted and it did not work
it thought it could be the memory
when i use sudo startx it works why does this work
JeremyF
Re: SOS HELP
Sat Sep 29, 2012 11:37 pm
eufc wrote:I haven't done anything with the sd card I just rebooted and it did not work
If sudo startx works but not startx, then that means that some files associated with the process of starting X are for whatever reason owned by root instead of pi. (the users, I mean)
jojopi
Re: SOS HELP
Sun Sep 30, 2012 12:10 am
JeremyF wrote:If sudo startx works but not startx, then that means that some files associated with the process of starting X are for whatever reason owned by root instead of pi. (the users, I mean)
No, it could just mean that the disk is full to non-superusers, as you originally suggested.
mahjongg
Re: Startx failing
Sun Sep 30, 2012 2:32 am
Edited subject line to something more sensible.
bredman
Re: Startx failing
Sun Sep 30, 2012 12:58 pm
Check how full the SD card is by using the command
df /
The percentage is shown on the right-hand side, anything above 95% means your disk is very full.
thebadbadger95
Re: Startx failing
Sat Jul 26, 2014 10:06 pm
I have had this problem too!
I'm going to reset the Sd card and carry on from there.
But I wonder why it happened I have never done anything (in the sense of having many huge files) and it was working yesterday now I turned it on today and bang this happens …
