otyugh
[solved]Certbot (LETSENCRYPT) - Illegal instruction
Tue Jun 27, 2017 9:23 am
Hey,
I couldn't succeed using certbot on raspbian jessie. I tried both installing it (and its dependency) from raspbian testing (deb http://mirrordirector.raspbian.org/raspbian/ testing main) and from debian arm jessie-backports (deb http://ftp.fr.debian.org/debian/ jessie-backports main).
All my tries resulted in an error-less installation, but certbot itself issues a "Illegal instruction" wathever the argument givent (or even with no argument at all).
I saw there were many problem around this, but I couldn't find any correct answer around it yet. It is, lot of people think, bind to the RPi architecture armv6 when debian arm uses armv7 ? - this would explains the fail for je jessie-backport. What about the raspbian testing issue, then ?
My actual testing ground is a RPi rev1B. I'm up to try stuffs if you have clues !
RaTTuS
Contact: Twitter YouTube
Re: Certbot (LETSENCRYPT) -
Tue Jun 27, 2017 10:51 am
you =will probably have to build it from source
Covfefe
Tue Jun 27, 2017 11:12 am
otyugh wrote:Hey,
You are correct that Debian Jessie ARMHF Hard Float is for ARMv7 instruction set, so totally an excercise in fruitality trying to use those packages !
Debian ARMEL supports ARMv4/5/6 Soft Float instruction set which was the original Operating System offered for the Raspberry Pi's.
So the way forward is to build from Source
RPi 4B 4GB (SSD Boot)..
Tue Jun 27, 2017 11:24 am
fruitoftheloom wrote: an excercise in fruitality
I see what you did there....
otyugh
Tue Jun 27, 2017 2:38 pm
Quite a loss of time there, fault of remaining backported packages : after struggling at "de-backport" my system (for others that do the same mistake : dpkg-query -W | grep ~bpo + apt-cache policy to know what version to downgrade + apt-get install package=version).
I then upgraded to realize some package where backported in the native raspbian jessie repo already (this is not very... inutitive).
Well, and then, installing certbot from raspbian stretch - worked.
Fieel
Re: [solved]Certbot (LETSENCRYPT) - Illegal instruction
Sun Apr 07, 2019 3:10 pm
Yup, updating the source.list and upgrading did the trick
