jayt80
mount error(5): Input/output error Refer to the mount.cifs
Fri Jun 23, 2017 1:35 am
Hi there,
I have tvheadend installed on my raspberry pi 3 (using latest version of raspbian) to use as the back end server for recording TV shows. I want to record to a usb drive on my network that is attached to my mac mini.
The USB drive connected to my Macmini is formatted to HFS+ non-journaled and has it's own power supply. I have created the SMB share on the mac so it's available to be seen on my network.
I've installed hfsplus hfsprogs hfsutils on the pi3.
This is what i've tried to use to mount the drive:
sudo mount -t cifs -o user={USER},password={PASS},rw //{IP}/{SHARE} /home/pi/recordings
sudo mount -t cifs -o user={USER},password={PASS},nounix,sec=ntlmssp,noperm,rw //{IP}/{SHARE} /home/pi/recordings
Both return the following error:
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Any help would be appreciated.
Thanks!
thagrol
Re: mount error(5): Input/output error Refer to the mount.ci
Fri Jun 23, 2017 1:19 pm
A quick google suggests "sec=ntlm" in the mount options might help
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
jayt80
Thu Jul 20, 2017 2:14 am
thagrol wrote:A quick google suggests "sec=ntlm" in the mount options might help
Thanks but i've already tried that and it doesn't work.
Jeromel1978
Re: mount error(5): Input/output error Refer to the mount.cifs
Fri Oct 20, 2017 3:21 am
Hi, I'm having the exact same issue. did you ever find a solution?
