Fri Jun 16, 2017 9:32 pm
naman1208 wrote:i was using my pi3 as a torrent download machine, it was working fine, i am using HDMI to DVI converter for the display because my monitor do not have an HDMI port, everything was working fine i was getting clear display but after some days i noticed some random spots on my screen and display was not clear it happened sometimes and sometimes it was clear but one day i was using my raspberry pi3 and suddenly display was gone all i could see is black screen i unplugged my raspberry pi and again tried but no luck, then i formatted the memorycard and reinstalled raspbian but it dosent work, still no display, both power and data leds are glowing which shows that my pi is booting properly so whats the problem behind that plz help
Are you sure you're using a HDMI-to-
DVI converter and not a HDMI-to-
VGA converter? No active
conversion is needed from HDMI to DVI since they're both, similar if not identical, digital video signals and the "conversion" is basically connecting one type of "plug" to another. HDMi to VGA however does require converting a digital signal to a (set of) analogue signals.
Trev.
