micksulley
Low Voltage Detection Not Working
Thu Jun 15, 2017 7:15 pm
Running a Pi3 with an official Raspi power supply, voltage measures 5.14v
I found some code
#!/usr/bin/python
import RPi.GPIO as GPIO , time
redLED=35
GPIO.setmode(GPIO.BCM)
GPIO.setup(redLED, GPIO.IN)
powerlow=0
while True:
    if(GPIO.input(redLED)==0):
          print "POWER dipped below 4.63v"
          powerlow += 1
    else:
          powerlow =0
    if (powerlow  > 3):
          print "Low power for " + str(powerlow) + " seconds"
    time.sleep(1)
in this post viewtopic.php?f=29&t=82373&hilit=under+ ... l&start=75
but when I run it it immediately reports "POWER dipped below 4.63v" and continues to do so. I have had a voltmeter connected at the same time and it reads 5.14v, so the voltage is not actually low. What can cause this? How can I reliably detect low voltage?
Mick
klricks
Re: Low Voltage Detection Not Working
Thu Jun 15, 2017 7:31 pm
Where are you measuring the 5V? You need to measure after the fuse and LV protection circuit such as at the GPIO pins and not at the micro USB power input or power supply.
micksulley
Thu Jun 15, 2017 7:40 pm
Yes measuring at GPIO.
Burngate
Fri Jun 16, 2017 8:50 am
Your code looks at GPIO-35, which on the B+ and 2B is connected to the voltage-sensing circuit.
Unfortunately on the 3B that circuit was moved onto an expander (to make room for the WiFi, etc.) so you're onto a loser.
I believe it's possible to read the GPIOs attached to that expander, using numbers around 130, but someone more knowledgeable than me could tell you more.
micksulley
Fri Jun 16, 2017 8:18 pm
Thanks for the info.
OK boffins, how can I do it?
