rachel1106
connot scan ip address when connect to my computer
Thu Jun 15, 2017 7:57 am
When I got my raspberry 3, i can use network cable to connect my computer and raspberry and then make my computer be a display screen. But yesterday when I do it again, I couldn't get raspberry ip address by using Advanced IP Scanner. I can see the ip which I used last time, but it was grey. And I reboot the system of raspberry, the promblem is still here. Can you help me? I'm new to raspberry. Thank you very much!
SurferTim
Re: connot scan ip address when connect to my computer
Thu Jun 15, 2017 8:58 am
You didn't provide enough info to get started.
How are the RPi and computer connected? Is there a router involved? Or just a cable from the RPi to the PC?
What IP did you use last time it worked?
Are you using Jessie/Pixel, Jessie Lite, or...?
