Nightforce2
JBONEST RTL8821AU Driver compile failure
Fri Jun 09, 2017 5:44 pm
Hello Raspians,
I have been fighting the problem of figuring out how to compile two drivers. In this case I will stick to this one for now and post later about the other one if needed after this one gets resolved.
The current hardware is a JBonest dualband AC Adapter for extending WIFI range and allowing for better speeds and connectivity.
The first problems I noticed when trying to configure the make file for compilation was that it was missing settings for CONFIG_PLATFORM_ARM_RPI out of the box, so I added them as so:
CONFIG_PLATFORM_I386_PC = n
CONFIG_PLATFORM_ANDROID_X86 = n
CONFIG_PLATFORM_ANDROID_INTEL_X86 = n
CONFIG_PLATFORM_JB_X86 = n
CONFIG_PLATFORM_ARM_S3C2K4 = n
CONFIG_PLATFORM_ARM_PXA2XX = n
CONFIG_PLATFORM_ARM_S3C6K4 = n
CONFIG_PLATFORM_ARM_RPI    = y
ifeq ($(CONFIG_PLATFORM_ARM_RPI), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN
EXTRA_CFLAGS += -DCONFIG_IOCTL_CFG80211 -DRTW_USE_CFG80211_STA_EVENT
ARCH := arm
CROSS_COMPILE :=
KVER := $(shell uname -r)
KSRC := /lib/modules/$(KVER)/build
MODDESTDIR := /lib/modules/$(KVER)/kernel/drivers/net/wireless/
INSTALL_PREFIX :=
endif
After saving and initiating make. I get several errors pertaining to symbols missing and debug problems not being ignored as usual. Here is what I get during compilation:
root@kali:/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51# make
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.4.50-v7/build M=/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51  modules
make[1]: Entering directory '/usr/src/kernel'
  WARNING: Symbol version dump ./Module.symvers
           is missing; modules will have no dependencies and modversions.
  CC [M]  /tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.o
In file included from /tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/drv_types.h:95:0,
                 from /tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.c:22:
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/hal_com.h:412:13: error: ‘file_path’ redeclared as different kind of symbol
 extern char file_path[PATH_LENGTH_MAX];
In file included from include/linux/cgroup.h:16:0,
                 from include/net/netprio_cgroup.h:17,
                 from include/linux/netdevice.h:48,
                 from /tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/osdep_service_linux.h:35,
                 from /tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/osdep_service.h:41,
                 from /tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/drv_types.h:32,
include/linux/fs.h:2574:14: note: previous declaration of ‘file_path’ was here
 extern char *file_path(struct file *, char *, int);
In file included from /tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/drv_types.h:65:0,
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.c: In function ‘btinfo_evt_dump’:
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/rtw_debug.h:187:19: error: void value not ignored as it ought to be
  #define _seqdump seq_printf
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/include/rtw_debug.h:242:7: note: in expansion of macro ‘_seqdump’
    if(_seqdump(sel, fmt, ##arg)) /*rtw_warn_on(1)*/; \
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.c:3293:2: note: in expansion of macro ‘DBG_871X_SEL_NL’
  DBG_871X_SEL_NL(sel, "cid:0x%02x, len:%u\n", info->cid, info->len);
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.c:3296:3: note: in expansion of macro ‘DBG_871X_SEL_NL’
   DBG_871X_SEL_NL(sel, "byte2:%s%s%s%s%s%s%s%s\n"
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.c:3308:3: note: in expansion of macro ‘DBG_871X_SEL_NL’
   DBG_871X_SEL_NL(sel, "retry_cnt:%u\n", info->retry_cnt);
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.c:3311:3: note: in expansion of macro ‘DBG_871X_SEL_NL’
   DBG_871X_SEL_NL(sel, "rssi:%u\n", info->rssi);
/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.c:3314:3: note: in expansion of macro ‘DBG_871X_SEL_NL’
   DBG_871X_SEL_NL(sel, "byte5:%s%s\n"
scripts/Makefile.build:258: recipe for target '/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.o' failed
make[2]: *** [/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.o] Error 1
Makefile:1402: recipe for target '_module_/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51' failed
make[1]: *** [_module_/tmp/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51] Error 2
make[1]: Leaving directory '/usr/src/kernel'
Makefile:1563: recipe for target 'modules' failed
make: *** [modules] Error 2
I read a few places that it might be a kernel version problem or might be linked to debugging being enabled? Is this my case and if so. How do I continue? If not, What am I missing? Both drivers on both hardware I tried have this exact same issue. Trying on both raspian and kali.
Below is required information requested:
uname -a
Linux kali 4.4.50-v7 #1 SMP Fri Apr 21 01:18:29 CDT 2017 armv7l GNU/Linux
dmsg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.50-v7 (root@builder) (gcc version 4.8.3 20140401 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) ) #1 SMP Fri Apr 21 01:18:29 CDT 2017
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 808e0a00, node_mem_map b9fa6000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9540->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22720 r8192 d22336 u53248
[    0.000000] pcpu-alloc: s22720 r8192 d22336 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 dma.dmachans=0x7f35 bcm2709.boardrev=0xa02082 bcm2709.serial=0xb062afa2 bcm2709.uart_clock=48000000 smsc95xx.macaddr=B8:27:EB:62:AF:A2 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.fiq_fix_enable=2 console=ttyS0,115200 kgdboc=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rootflags=noload net.ifnames=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 938944K/966656K available (6436K kernel code, 440K rwdata, 1732K rodata, 484K init, 772K bss, 19520K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                   lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
                   modules : 0x7f000000 - 0x80000000   (  16 MB)
                     .text : 0x80008000 - 0x808023b0   (8169 kB)
                     .init : 0x80803000 - 0x8087c000   ( 484 kB)
                     .data : 0x8087c000 - 0x808ea0e8   ( 441 kB)
                      .bss : 0x808ed000 - 0x809ae22c   ( 773 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000285] Console: colour dummy device 80x30
[    0.001338] console [tty1] enabled
[    0.001383] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001452] pid_max: default: 32768 minimum: 301
[    0.001789] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001832] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002810] Disabling cpuset control group subsystem
[    0.002869] Initializing cgroup subsys io
[    0.002921] Initializing cgroup subsys memory
[    0.002987] Initializing cgroup subsys devices
[    0.003032] Initializing cgroup subsys freezer
[    0.003073] Initializing cgroup subsys net_cls
[    0.003114] Initializing cgroup subsys perf_event
[    0.003155] Initializing cgroup subsys net_prio
[    0.003206] Initializing cgroup subsys pids
[    0.003273] CPU: Testing write buffer coherency: ok
[    0.003364] ftrace: allocating 21587 entries in 64 pages
[    0.053182] CPU0: update cpu_capacity 1024
[    0.053251] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.053285] [bcm2709_smp_prepare_cpus] enter
[    0.053438] Setting up static identity map for 0x8240 - 0x8274
[    0.055123] [bcm2709_boot_secondary] cpu:1 started (0) 17
[    0.055474] [bcm2709_secondary_init] enter cpu:1
[    0.055512] CPU1: update cpu_capacity 1024
[    0.055518] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.055907] [bcm2709_boot_secondary] cpu:2 started (0) 18
[    0.056168] [bcm2709_secondary_init] enter cpu:2
[    0.056189] CPU2: update cpu_capacity 1024
[    0.056194] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.056561] [bcm2709_boot_secondary] cpu:3 started (0) 17
[    0.056742] [bcm2709_secondary_init] enter cpu:3
[    0.056762] CPU3: update cpu_capacity 1024
[    0.056768] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.056829] Brought up 4 CPUs
[    0.056927] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.056956] CPU: All CPU(s) started in HYP mode.
[    0.056982] CPU: Virtualization extensions available.
[    0.057645] devtmpfs: initialized
[    0.068420] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.068795] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.069506] pinctrl core: initialized pinctrl subsystem
[    0.070078] NET: Registered protocol family 16
[    0.075260] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.082020] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.082069] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.082240] Serial: AMBA PL011 UART driver
[    0.082390] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.082619] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.145312] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[    0.145924] SCSI subsystem initialized
[    0.146126] usbcore: registered new interface driver usbfs
[    0.146236] usbcore: registered new interface driver hub
[    0.146353] usbcore: registered new device driver usb
[    0.152724] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-04-19 13:30
[    0.179932] clocksource: Switched to clocksource arch_sys_counter
[    0.223371] FS-Cache: Loaded
[    0.223683] CacheFiles: Loaded
[    0.236030] NET: Registered protocol family 2
[    0.236899] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.237037] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.237247] TCP: Hash tables configured (established 8192 bind 8192)
[    0.237361] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.237429] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.237682] NET: Registered protocol family 1
[    0.238038] RPC: Registered named UNIX socket transport module.
[    0.238070] RPC: Registered udp transport module.
[    0.238097] RPC: Registered tcp transport module.
[    0.238125] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.239159] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.240598] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.254229] VFS: Disk quotas dquot_6.6.0
[    0.254563] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.256841] FS-Cache: Netfs 'nfs' registered for caching
[    0.257790] NFS: Registering the id_resolver key type
[    0.257868] Key type id_resolver registered
[    0.257896] Key type id_legacy registered
[    0.263234] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.263402] io scheduler noop registered
[    0.263438] io scheduler deadline registered
[    0.263508] io scheduler cfq registered (default)
[    0.266051] BCM2708FB: allocated DMA memory fac10000
[    0.266098] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.316787] Console: switching to colour frame buffer device 228x61
[    0.346984] bcm2835-rng 3f104000.rng: hwrng registered
[    0.347228] vc-cma: Videocore CMA driver
[    0.347348] vc-cma: vc_cma_base      = 0x00000000
[    0.347487] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.347643] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.347998] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    0.363279] brd: module loaded
[    0.372046] loop: module loaded
[    0.373114] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[    0.374875] Loading iSCSI transport class v2.0-870.
[    0.375674] usbcore: registered new interface driver smsc95xx
[    0.375894] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.576357] Core Release: 2.80a
[    0.576464] Setting default values for core params
[    0.576634] Finished setting default values for core params
[    0.777160] Using Buffer DMA mode
[    0.777267] Periodic Transfer Interrupt Enhancement - disabled
[    0.777435] Multiprocessor Interrupt Enhancement - disabled
[    0.777596] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.777736] Dedicated Tx FIFOs mode
[    0.778153] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac04000 dma = 0xfac04000 len=9024
[    0.778450] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.785662] dwc_otg: Microframe scheduler enabled
[    0.785713] WARN::hcd_init_fiq:415: FIQ on core 1 at 0x80458c70
[    0.792531] WARN::hcd_init_fiq:416: FIQ ASM at 0x80458fd4 length 36
[    0.799370] WARN::hcd_init_fiq:441: MPHI regs_base at 0xbb87e000
[    0.806153] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.812947] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.819709] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.826465] Init: Port Power? op_state=1
[    0.833157] Init: Power Port (0)
[    0.839888] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.846646] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.853355] usb usb1: Product: DWC OTG Controller
[    0.860164] usb usb1: Manufacturer: Linux 4.4.50-v7 dwc_otg_hcd
[    0.867011] usb usb1: SerialNumber: 3f980000.usb
[    0.874581] hub 1-0:1.0: USB hub found
[    0.881292] hub 1-0:1.0: 1 port detected
[    0.888488] dwc_otg: FIQ enabled
[    0.888498] dwc_otg: NAK holdoff enabled
[    0.888506] dwc_otg: FIQ split-transaction FSM enabled
[    0.888545] Module dwc_common_port init
[    0.888812] usbcore: registered new interface driver usb-storage
[    0.895744] mousedev: PS/2 mouse device common for all mice
[    0.903042] bcm2835-cpufreq: min=600000 max=1200000
[    0.909863] sdhci: Secure Digital Host Controller Interface driver
[    0.916498] sdhci: Copyright(c) Pierre Ossman
[    0.923382] sdhost: log_buf @ bac07000 (fac07000)
[    0.989960] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.998865] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    1.005423] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    1.050048] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.056992] ledtrig-cpu: registered to indicate activity on CPUs
[    1.063863] hidraw: raw HID events driver (C) Jiri Kosina
[    1.070724] usbcore: registered new interface driver usbhid
[    1.077498] usbhid: USB HID core driver
[    1.084330] Indeed it is in host mode hprt0 = 00021501
[    1.089973] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.093017] mmc0: new high speed SDHC card at address aaaa
[    1.093737] mmcblk0: mmc0:aaaa AGGCD 29.7 GiB
[    1.094030] Initializing XFRM netlink socket
[    1.094074] NET: Registered protocol family 17
[    1.094241] Key type dns_resolver registered
[    1.094789] Registering SWP/SWPB emulation handler
[    1.095663] registered taskstats version 1
[    1.098859]  mmcblk0: p1 p2
[    1.099291] Key type encrypted registered
[    1.099380] vc-sm: Videocore shared memory driver
[    1.099389] [vc_sm_connected_init]: start
[    1.099963] [vc_sm_connected_init]: end - returning 0
[    1.101307] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.101675] of_cfs_init
[    1.101761] of_cfs_init: OK
[    1.113992] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.115540] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.117088] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.119869] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.210004] mmc1: new high speed SDIO card at address 0001
[    1.246945] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: noload
[    1.253292] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.263745] devtmpfs: mounted
[    1.270730] Freeing unused kernel memory: 484K (80803000 - 8087c000)
[    1.409995] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.416797] Indeed it is in host mode hprt0 = 00001101
[    1.594447] systemd[1]: System time before build time, advancing clock.
[    1.620254] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    1.626979] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.634595] hub 1-1:1.0: USB hub found
[    1.641365] hub 1-1:1.0: 5 ports detected
[    1.701225] NET: Registered protocol family 10
[    1.726759] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.749315] random: systemd: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[    1.758932] random: systemd: uninitialized urandom read (16 bytes read, 59 bits of entropy available)
[    1.769661] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    1.777496] systemd[1]: Detected architecture arm.
[    1.828929] systemd[1]: Set hostname to <kali>.
[    1.916083] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[    1.920164] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.921326] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[    1.956153] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[    1.960623] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[    1.961036] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[    2.020346] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.027969] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.038327] smsc95xx v1.0.4
[    2.103383] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:62:af:a2
[    2.144831] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    2.325558] random: systemd: uninitialized urandom read (16 bytes read, 73 bits of entropy available)
[    2.333844] random: systemd: uninitialized urandom read (16 bytes read, 73 bits of entropy available)
[    2.350018] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[    2.474679] usb 1-1.3: New USB device found, idVendor=054c, idProduct=005d
[    2.482554] usb 1-1.3: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[    2.490321] usb 1-1.3: Product: SCE USB Keyboard Hub
[    2.498118] usb 1-1.3: Manufacturer: Sony Computer Entertainment Inc.
[    2.508755] hub 1-1.3:1.0: USB hub found
[    2.517191] hub 1-1.3:1.0: 2 ports detected
[    2.536948] systemd[1]: Listening on fsck to fsckd communication Socket.
[    2.554317] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.571269] systemd[1]: Reached target Remote File Systems.
[    2.588433] systemd[1]: Listening on udev Kernel Socket.
[    2.605522] systemd[1]: Listening on LVM2 poll daemon socket.
[    2.623182] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.641140] systemd[1]: Listening on Syslog Socket.
[    2.659374] systemd[1]: Listening on udev Control Socket.
[    2.678321] systemd[1]: Created slice System Slice.
[    2.720346] systemd[1]: Mounting Debug File System...
[    2.739902] systemd[1]: Reached target Swap.
[    2.760283] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    2.780220] systemd[1]: Created slice User and Session Slice.
[    2.799992] usb 1-1.3.1: new full-speed USB device number 5 using dwc_otg
[    2.801755] systemd[1]: Mounting POSIX Message Queue File System...
[    2.830576] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.849354] systemd[1]: Listening on Journal Socket.
[    2.924604] usb 1-1.3.1: New USB device found, idVendor=054c, idProduct=005c
[    2.930562] systemd[1]: Starting Load Kernel Modules...
[    2.942670] usb 1-1.3.1: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[    2.942679] usb 1-1.3.1: Product: SCE USB Keyboard
[    2.942697] usb 1-1.3.1: Manufacturer: Sony Computer Entertainment Inc.
[    2.975480] input: Sony Computer Entertainment Inc. SCE USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:054C:005C.0001/input/input0
[    2.992053] systemd[1]: Starting Set the console keyboard layout...
[    3.016683] systemd[1]: Starting File System Check on Root Device...
[    3.031515] hid-generic 0003:054C:005C.0001: input,hidraw0: USB HID v1.00 Keyboard [Sony Computer Entertainment Inc. SCE USB Keyboard] on usb-3f980000.usb-1.3.1/input0
[    3.048475] systemd[1]: Listening on LVM2 metadata daemon socket.
[    3.170618] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    3.193243] systemd[1]: Reached target Slices.
[    3.214205] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.234300] systemd[1]: Reached target Paths.
[    3.254117] systemd[1]: Reached target Encrypted Volumes.
[    3.274820] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.308823] systemd[1]: Starting Journal Service...
[    3.332354] systemd[1]: Created slice system-getty.slice.
[    3.366145] systemd[1]: Mounted Debug File System.
[    3.388058] systemd[1]: Mounted POSIX Message Queue File System.
[    3.411260] systemd[1]: Started Load Kernel Modules.
[    3.438413] systemd[1]: Started File System Check on Root Device.
[    3.461140] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    3.483598] systemd[1]: Started Journal Service.
[    3.634753] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[    4.031553] systemd-journald[164]: Received request to flush runtime journal from PID 1
[    4.560924] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    4.583999] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    4.873140] usbcore: registered new interface driver brcmfmac
[    5.013702] cfg80211: World regulatory domain updated:
[    5.013716] cfg80211:  DFS Master region: unset
[    5.013717] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    5.013731] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    5.013739] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    5.013746] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    5.013754] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    5.013763] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    5.013770] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    5.013776] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    5.013783] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    5.096951] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[    5.127434] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    5.987673] random: nonblocking pool is initialized
[    6.791191] Bluetooth: Core ver 2.21
[    6.802370] NET: Registered protocol family 31
[    6.813291] Bluetooth: HCI device and connection manager initialized
[    6.824154] Bluetooth: HCI socket layer initialized
[    6.835344] Bluetooth: L2CAP socket layer initialized
[    6.846315] Bluetooth: SCO socket layer initialized
[    6.865262] Netfilter messages via NETLINK v0.30.
[    7.322861] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    7.334185] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.865636] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    7.916035] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[    7.925656] brcmfmac: brcmf_add_if: ignore IF event
[    7.940952] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    7.951146] brcmfmac: power management disabled
[    8.476963] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    8.487000] brcmfmac: power management disabled
[    8.876089] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[    8.885588] brcmfmac: brcmf_add_if: ignore IF event
[    8.896122] brcmfmac: brcmf_p2p_create_p2pdev: set p2p_disc error
[    8.929028] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   30.749972] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[   30.870685] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=a811
[   30.880395] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   30.889423] usb 1-1.4: Product: 802.11ac WLAN Adapter
[   30.898574] usb 1-1.4: Manufacturer: Realtek
[   30.907369] usb 1-1.4: SerialNumber: 00e04c000001
[   47.139972] usb 1-1.5: new low-speed USB device number 7 using dwc_otg
[   47.268257] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c521
[   47.277729] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   47.287109] usb 1-1.5: Product: USB Receiver
[   47.296882] usb 1-1.5: Manufacturer: Logitech
[   47.328270] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:046D:C521.0002/input/input1
[   47.338763] hid-generic 0003:046D:C521.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.5/input0
[   47.371141] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:046D:C521.0003/input/input2
[   47.440964] hid-generic 0003:046D:C521.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.5/input1
[   90.800496] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   90.800555] brcmfmac: power management disabled
[   91.607000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  163.099916] device wlan0 entered promiscuous mode
[  185.651175] device wlan0 left promiscuous mode
[  226.879823] usb 1-1.2: new high-speed USB device number 8 using dwc_otg
[  227.340580] usb 1-1.2: New USB device found, idVendor=1e1d, idProduct=1103
[  227.340603] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  227.340617] usb 1-1.2: Product: SS3
[  227.340630] usb 1-1.2: Manufacturer: Kanguru
[  227.340642] usb 1-1.2: SerialNumber: 07074B95DD1F3858
[  227.341612] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[  227.341981] scsi host0: usb-storage 1-1.2:1.0
[  228.340680] scsi 0:0:0:0: Direct-Access     Kanguru  SS3              PMAP PQ: 0 ANSI: 6
[  228.342909] sd 0:0:0:0: [sda] 61767680 512-byte logical blocks: (31.6 GB/29.5 GiB)
[  228.343572] sd 0:0:0:0: [sda] Write Protect is off
[  228.343597] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[  228.343882] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  228.373930] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  228.547366]  sda: sda1
[  228.549466] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  234.832986] fuse init (API version 7.23)
lsusb -v
Bus 001 Device 007: ID 046d:c521 Logitech, Inc. Cordless Mouse Receiver
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x046d Logitech, Inc.
  idProduct          0xc521 Cordless Mouse Receiver
  bcdDevice           57.00
  iManufacturer           1 Logitech
  iProduct                2 USB Receiver
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          4 RR57.00_B0016
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               98mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      67
         Report Descriptors:
           ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      79
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Bus 001 Device 006: ID 0bda:a811 Realtek Semiconductor Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bda Realtek Semiconductor Corp.
  idProduct          0xa811
  bcdDevice            2.00
  iManufacturer           1 Realtek
  iProduct                2 802.11ac WLAN Adapter
  iSerial                 3 00e04c000001
    bLength                 9
    bDescriptorType         2
    wTotalLength           60
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           6
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              2 802.11ac WLAN Adapter
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               3
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x08  EP 8 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x09  EP 9 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength           12
  bNumDeviceCaps          1
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000002
      Link Power Management (LPM) Supported
Device Status:     0x0001
  Self Powered
Bus 001 Device 005: ID 054c:005c Sony Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x054c Sony Corp.
  idProduct          0x005c
  bcdDevice            0.01
  iManufacturer           3 Sony Computer Entertainment Inc.
  iProduct                2 SCE USB Keyboard
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          2 SCE USB Keyboard
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Keyboard
      iInterface              2 SCE USB Keyboard
          bLength                 9
          bDescriptorType        33
          bcdHID               1.00
          bCountryCode           33 US
          bNumDescriptors         1
          wDescriptorLength      65
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
  (Bus Powered)
Bus 001 Device 004: ID 054c:005d Sony Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0         8
  idProduct          0x005d
  bcdDevice            0.01
  iProduct                1 SCE USB Keyboard Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
    Per-port overcurrent protection
  bPwrOn2PwrGood       22 * 2 milli seconds
  bHubContrCurrent    100 milli Ampere
  DeviceRemovable    0x02
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0103 power enable connect
   Port 2: 0000.0100 power
  (Bus Powered)
Bus 001 Device 008: ID 1e1d:1103 Lumension Security
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x1e1d Lumension Security
  idProduct          0x1103
  bcdDevice            1.10
  iManufacturer           1 Kanguru
  iProduct                2 SS3
  iSerial                 3 07074B95DD1F3858
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              498mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  bLength                 5
  bDescriptorType        15
  wTotalLength           22
  bNumDeviceCaps          2
    bLength                 7
    bDescriptorType        16
    bmAttributes   0x00000006
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   2
      Lowest fully-functional device speed is High Speed (480Mbps)
    bU1DevExitLat          10 micro seconds
    bU2DevExitLat        2047 micro seconds
  (Bus Powered)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idProduct          0x9514 SMC9514 Hub
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
    Compound device
    TT think time 8 FS bits
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent      1 milli Ampere
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0503 highspeed power enable connect
   Port 3: 0000.0103 power enable connect
   Port 4: 0000.0503 highspeed power enable connect
   Port 5: 0000.0303 lowspeed power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.04
  iManufacturer           3 Linux 4.4.50-v7 dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 3f980000.usb
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
 Hub Port Status:
  Self Powered
:Update 17:49:
After commenting out a few of the macro statements used in rtw_cmd.c and hal_com.h. A few of the errors have disappeared. Also using the command
make modules
Does not generate Module.symvers as required for compilation.
lines 410-414 of hal_com.h
#ifdef CONFIG_LOAD_PHY_PARA_FROM_FILE
extern char *rtw_phy_file_path;
/*extern char file_path[PATH_LENGTH_MAX];*/ <-- duplicate as it is defined somewhere else in kernel tree.
#define GetLineFromBuffer(buffer)   strsep(&buffer, "\n")
#endif
lines 3289-3318 rtw_cmd.c
void btinfo_evt_dump(void *sel, void *buf) // This should be ok since it should not need debug code in a release build.
	/*struct btinfo *info = (struct btinfo *)buf;
	if (info->len > 2)
			, info->bConnection?"bConnection ":""
			, info->bSCOeSCO?"bSCOeSCO ":""
			, info->bInQPage?"bInQPage ":""
			, info->bACLBusy?"bACLBusy ":""
			, info->bSCOBusy?"bSCOBusy ":""
			, info->bHID?"bHID ":""
			, info->bA2DP?"bA2DP ":""
			, info->bFTP?"bFTP":""
	if (info->len > 3)
	if (info->len > 4)
	if (info->len > 5)
			, info->eSCO_SCO?"eSCO_SCO ":""
			, info->Master_Slave?"Master_Slave ":""
New errors are as follows:
# make modules
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.4.50-v7/build M=/root/Desktop/jbonest/Driver/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51  modules
  CC [M]  /root/Desktop/jbonest/Driver/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.o
/bin/sh: 1: ./scripts/recordmcount: Exec format error
scripts/Makefile.build:258: recipe for target '/root/Desktop/jbonest/Driver/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.o' failed
make[2]: *** [/root/Desktop/jbonest/Driver/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/core/rtw_cmd.o] Error 2
Makefile:1402: recipe for target '_module_/root/Desktop/jbonest/Driver/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51' failed
make[1]: *** [_module_/root/Desktop/jbonest/Driver/linux/driver/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51/rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51] Error 2
RamsesV
Re: JBONEST RTL8821AU Driver compile failure
Mon Aug 07, 2017 9:20 am
I run into a similar problem recently with the RTL8821AU driver and was able to find the solution (not easy to find the right place though). It seems the driver needs a couple of modifications to be compiled by Raspbian.
Anyway, the solution is referenced here:
https://www.erol.name/compile-realtek-r ... an-jessie/
and the actual right version of the driver can be downloaded here:
https://github.com/abperiasamy/rtl8812AU_8821AU_linux
Nightforce2
Sun Aug 20, 2017 8:02 pm
RamsesV,
First off, Thank you for your reply. I found out how to get it workiong on the vanilla version of jesse. It took me a bit of researching but it it came down to using the Rpi-source tool located here https://github.com/notro/rpi-source/wiki.
Also had to change make file to include and enable the RPI for compile. Have not gotten around to test out your solution. Will try todo that in the future.
RamsesV
Wed Aug 23, 2017 10:17 am
As I said, it worked for me, and the cool thing is that this version of the driver already includes a definition for the RPI in the makefile, so to compile on the Pi you just need to do little modifications to choose the right options in the makefile (all described in the links that I included before). :)
Anyway, good to know you were able to get it running using some other way and hopefully my proposed solution will work for you if you ever try it. :)
Caryev
Tue Oct 30, 2018 10:43 am
HI @RamsesV,
after following the instructions from https://www.erol.name/compile-realtek- ... an-jessie/ for raspberrypi, everything went well. However, I also wanted to test the driver rtl8821au and got the following results:
$sudo modprobe -a rtl8812au
modeprobe: WARNING: Module rtl8821au not found in directory /lib/moduels/4.14.71+
Does this mean that the driver rtl8821au was not installed? Or its configuration is also included in the driver rtl8812au? Should the driver rtl8821 also work?
I can see that the Makefile has this configuration:
########################## WIFI IC ############################
CONFIG_MULTIDRV = n
CONFIG_RTL8192C = n
CONFIG_RTL8192D = n
CONFIG_RTL8723A = n
CONFIG_RTL8188E = n
CONFIG_RTL8812A = y
CONFIG_RTL8821A = y
CONFIG_RTL8192E = n
CONFIG_RTL8723B = n
